Color Coding on GC Loader Valve
   / Color Coding on GC Loader Valve #11
pcwolf, is your leak from the joy stick side of the valve spools,the detent cap end, or the quick connects?
   / Color Coding on GC Loader Valve #12
DMW ... from the loader disconnect closest to the driver - top inside rear. I have a 2005 with individual hookups.
-Phil
   / Color Coding on GC Loader Valve #13
There's not really anything you can lose, just try to keep everything clean. It might me a good idea to take off the loader, gives a lot better access to the valve. If you ever have to replace any spool o rings, definitely remove the loader.
   / Color Coding on GC Loader Valve #14
Thanks. I will look for an opportunity to observe a rebuild if I get the chance. I have never worked with hydraulics before owning this GC2310.
-Phil
   / Color Coding on GC Loader Valve #15
Replacing the 0 rings on the valve is not much different than fixing a leaking kitchen tap (technically also a hydraulic system). Just be sure the system isn't pressurized. Remove the loader, lower the 3 pt attachment or backhoe so they are on the ground and cannot create any system pressure by dropping. Shut the tractor off. Move the joysticks around, depress the nipples on the quick connects on the valve body your working on. Same goes for replacing any leaking hydraulic lines.Your work on the cooling fan/steering washers was a much more involved job.
2015 Ford F-750 Crew Cab Liftmoore 2550 5000LB Mechanics Crane Truck (A48081)
2015 Ford F-750...
2008 John Deere 9570 STS Combine - Front Duals - Premium Cab - 1,704 Sep Hours - Clean & Field-Re... (A50397)
2008 John Deere...
NEW 2022 Load Trail CH 83IN x 18FT Equipment Trailer (A50397)
NEW 2022 Load...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A48081)
2016 Ford F-150...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
