Cheap Start to Reloading?
   / Cheap Start to Reloading? #101
I don't particulary like the looks of that plated jacket shedding. A lot of the guys are using the coated lead bullets now. Lots of info on youtube on how to make them. You can buy them as well from several places.
All About Polymer-Coated Bullets | Range365
Hi-Tek Polymer Coated Bullets for Reloading | Badman Bullets
Coated Bullets, Bullets for Reloading, Competition Bullets - Bayou Bullets
Black Bullets international - Coated Bullets / Projectiles, Bullets For Idpa / Uspsa / Bullseye / 3gun / Competition Shooters
i have been shooting them, I love them.
   / Cheap Start to Reloading? #102
I use a "bench" similar to a Black and Decker Workmate, but it has a solid fixed top and does not fold. Works great, easy to move.
Just finished loading up another 100 rnds of 115 gr Berrys with 5.2 gr CFE Pistol, 1.10" OAL, more flare on case mouth, and only enough crimp to set the flare back to straight.
Also, I picture of my set up, just for laughs. Right now, press is attached to a 2x6 and 3/4" plywood, c-clamped to a TV try table.
I'm thinking the jacket/plated issue comes from not enough flare, letting the case mouth gouge the plating, combined with a bit too much crimp. We will see
View attachment 544524View attachment 544525
Just ordered 500 Xtreme 124 gr plated hollow points, for $45.
So, I've tried YouTube and Google, does anyone know anything about casting and/or reloading .410 slugs? I can't seem to find a mold actually made for it, and I'm not really sure how well a .401 diameter pistol bullet will fly in an unrifled barrel. Also, the full coke measures like 0.395". Is my only option for that to loaf 0.395" round balls?
   / Cheap Start to Reloading? #105
lyman 410-859 should make a 138gr slug.
I believe they mic out at .385"
So, I bidding on a package deal 0.375 and 0.406 round ball molds for the .410.
I just loaded up 50 of the 124 Gr Xtreme plated hollow points. 5.0gr CFE Pistol, 1.123" OAL with Winchester small pistol primers.
The Xtremes weight between 124.1 and 124.9 gr on a 10 bullet sample and diameter was 0.3545".
   / Cheap Start to Reloading? #108
So far Paul, how's the cheap part working out for ya?
Well... I think my goal was to be reloading ammo with $150. I think I was at around $165 in order to crank out my first 100 rounds.
Since then I've added Lube, Lemashine, primer flip tray, and more projectiles, so I'm probably around $275 total, which includes having loaded right around 500 rounds so far, with components on hand to load another 575.
So, for $275 for around 1000 rnds, if you count only for cheap Full Metal Jacket the store-bought would have been cheaper, but not by very much
Is it realistic too knock out 50 rounds in an hour on a single stage if your using pre set dies with bushings? Measuring each charge with dipper and trickling up to +/- 0.2 grs?
So, it takes me about 2 hrs to turn out 50 rnds, measuring each charge to exact weight. Some times I might keep a 0.1 gr over. The scopes are no where near 0.2 accurate....
2015 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2015 Ford F-450...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
2014 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2014 Ford F-450...
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52128)
2013 Doyle Dry...
2012 Ford F-150 Crew Cab Pickup Truck (A50323)
2012 Ford F-150...
UNUSED CFG Industrial MX12RX Mini Excavator (A47384)
UNUSED CFG...
