Pushing Water Uphill: PTO pump or HF Predator?
   / Pushing Water Uphill: PTO pump or HF Predator? #51
It looks like you are using ball valves.
I switched about a half dozen garden valves and faucets to ball valves several years ago. Some are horizontal and some are vertical. I lose about one a year to freezing that cracks the housing beside the ball. I do drain the lines and leave the valves about half open or fully closed after draining to try to not trap water inside the ball housing. Still some water gets trapped inside, freezes, and cracks. It may be due to lots of rain, then condensation building up inside.
Bruce
Bruce
Well, shoot, I picked (expensive) metal ball valves on purpose for their durability and low restriction. And everything is designed for gravity drain. I hadn't thought water would get behind the metal ball.
~Bob
you may want to consider painting the exposed pvc pipes. i have pvc for a sump pump exposed, it got a bit brittle after 5-7 years
is the blue poly, pex? if so that definitely needs to be covered. pex will crack in short order in the sun
Not pex. Blue poly; usually buried. Don't know how well they'll do in the sun. When I bought a bunch it was stacked in rolls out in the sun. I am wondering if I need to go and paint everything just for UV protection. Rattle-can silver on the blue poly won't be hard and will blend with the fence. All that white PVC? That would be a bummer to go back and paint it white.
~Bob
   / Pushing Water Uphill: PTO pump or HF Predator? #54
Cracked ball valves:
ball valve cracked - Google Search
This hasn't always worked, but maybe a valve got turned and I didn't notice.
Bruce
   / Pushing Water Uphill: PTO pump or HF Predator? #55
Wooden Dining Table (A55853)
Wooden Dining...
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
2016 Ford F-450 12ft Flatbed Truck (A55852)
2016 Ford F-450...
2015 Toro Reelmaster 3 Gang Mower (A55851)
2015 Toro...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2000 FORD F-350 SUPER DUTY BUCKET TRUCK (A52472)
2000 FORD F-350...
