Need Insight/Advise on Changing Well Pressure Tank
   / Need Insight/Advise on Changing Well Pressure Tank #11
Gordon Gould;5097812 Unless there is a premature failure I won't be around to do thi s next time so I put it back the way it was. Otherwise I would have put in a union which is a good idea. gg[/QUOTE said:
That's how think too.
I know when I'm 70 I ain't pulling on no 30 year roof!
:laughing:
   / Need Insight/Advise on Changing Well Pressure Tank #12
Building my own house gave the luxury of doing things just different enough because I knew someday I would be the one having to repair stuff. My pressure tank has a shut off then a union and a drain on the pipe that goes to it. I can shut off the water going to the tank and drain just it out when the time comes (and it will) when I have to replace the PT.
   / Need Insight/Advise on Changing Well Pressure Tank #13
That is my philosophy also. Fix it right the first time and things are very simple the next time around. If you have a reoccurring problem, solve the problem and be done with it. In a few years, you have no more problems.
2022 CATERPILLAR 259D3 SKID STEER (A51246)
2022 CATERPILLAR...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A53472)
2012 JOHN DEERE...
2017 Rogator RG1300B Dry Fertilizer Applicator (A53472)
2017 Rogator...
2014 Ford Taurus AWD Sedan (A51694)
2014 Ford Taurus...
2024 John Deere 410R Sprayer (A53342)
2024 John Deere...
