Sliding axle gooseneck
   / Sliding axle gooseneck #1
moparrob
SW Idaho
2008 Kubota M59
Hello- I'm looking for a deckover gooseneck flatbed to haul hay and my Kubota M59 for some jobs to pay for itself. I've rented beavertail flatbeds and really disliked the rear clearance going up driveways etc. and I keep seeing an old Load-All 22' gooseneck slide axle for sale. It has been for sale over a year now, and I'm intrigued. I cant find any info on the Load-all brand online, but the concept seems handy, and this machine has a winch up front, with a pulley almost to the rear. Would the winch be used to move the 3 axles back and forth, or do I use the truck forward or backwards with the trailer brakes engaged? Are they worth the hassle or should I look for a hydraulic tilt, or a fixed bed with big ramps? I'd pay no more than $5000 as it needs batteries and tires.
   / Sliding axle gooseneck #2
I just got a load trail gooseneck dump and it seems well built. As for a tilt or sliding axle trailer can't help you. I have a dove tail gooseneck trailer and have not had much problem with it dragging, but really want to upgrade it to a hydraulic dovetail trailer easier to load and no ramps.
Here is dealer I got my load trail trailer from. Used Trailers For Sale Arthur Used Tractors For Sale Bloomington IL Champaign IL Kate's Kars & Trailer Sales Inc
   / Sliding axle gooseneck #3
I’d imagine the winch would move the axles. Neat concept, but if you are just pulling your tlb and hay might be unnecessary. If you were hauling slot of different stuff and really needed to screw with tongue weight than I could see the need. I’m not a fan of the really long ramps for a flat deck trailer. They will be really heavy.
   / Sliding axle gooseneck #4
Usually the axel locking mechanism is loosened and the electric brakes are set or the tires are blocked. Drive the rig back and forth as needed to get close to the right setting. The locking mechanism can be engaged and will drop into the hole when you get to it.
   / Sliding axle gooseneck #5
More info:
I have been considering a gooseneck deck over rollback trailer, but tend to procrastinate, so am still waiting for me to do it.
   / Sliding axle gooseneck #6
Nice pics X. I've never saw a trailer like that.
   / Sliding axle gooseneck #7
Never seen it in smaller trailers but the majority of semi trailers have sliding tandems.
Lock the brakes, pull the pin release and slide, then make sure pins are back in.
It is done with semi's to get axle weight legal most of the time.
I used to pull a 48' Landoll flatbed that had hydraulic sliding tandem.
It had about a 15' ram to move tandem. I even used it to get unstuck!
And with tandem all the way forward it was like backing a 20' trailer.
Tandem had to be back for highway use.
I think a goose with slider would be great!
Show us pics of it.
   / Sliding axle gooseneck #8
Pictures to prove it exists. This one is a combination sliding axle and tilt It would have less overhang behind the axles than a regular tilt:
When I was looking, Kwik Load said they could build a 16K GN Rollback for me, but I didn't pursue it any further because I am still able to lift the ramps on my 22' deckover 14K GN.
   / Sliding axle gooseneck #9
About the only thing wrong with a manual sliding axle setup is having every thing aligned so the pins pull easily. Stop for a moment and thing about how many "big truck" trailers that are out there on the road with manual sliding tandems? Other than meeting bridge laws and making it easier to drag a trailer around corners, being able to slide the trailer axles is more useful to back into a tight sight or for a roll off situation.
   / Sliding axle gooseneck #10
Show us pics of it.
Sliding tandems on a semi trailer isn't what this discussion is about. The ability to tilt and drop the bed to the ground is what's significant. X has posted some great pics!!!
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
2008 FORD F-350 XL SUPER DUTY CREW CAB TRUCK (A58375)
2008 FORD F-350 XL...
LOT: (4) Large Wheel Chocks (A59076)
LOT: (4) Large...
GENIE S-60 MANLIFT (A58216)
GENIE S-60 MANLIFT...
2015 Ford F-750 Stellar 10628 10,000LB 5 Ton Crane Mechanics Truck (A56858)
2015 Ford F-750...
SKID STEER ATTACHMENT ROCK SIFTER WITH BUCKET (A58216)
SKID STEER...
