The Great Grease Gun Coupler Showdown
   / The Great Grease Gun Coupler Showdown #71
Yep, it was discussed in this old thread: http://www.tractorbynet.com/forums/...ease-gun-coupler-post3815714.html#post3815714
Here is my long version:
I squirt a lot of grease. Best investment I ever made was a battery powered gun. Don't need any type of locking fitting with that.
   / The Great Grease Gun Coupler Showdown #73
The Univer-Co coupler also uses locking jaws. But they are controlled by a sliding outer collar. This collar has a flange that can be pulled. Normal position is open. To attach the Univer-Co you simply push it onto the Zerk like an ordinary coupler. When pressure is applied to the Zerk this releases the collar and it slides forward and it's locked on. Pump grease. Then pull the outer collar to release the locking jaws and remove the coupler from the Zerk. It rests in the unlocked position ready for the next Zerk.
View attachment 430537 View attachment 430538 View attachment 430539
Having to slide back a collar with greasy fingers gets a no vote from me. I've been very satisfied with my lock-n-lube so far. Works even with greasy gloves on and I haven't accidentally pulled out a zerk fitting yet.
FYI I bought one of these air operated grease pumps with an 18L pail on sale at PA.
18 Litre Air Grease Pump | Princess Auto
This with the Lock-n-lube on a 16" rubber hose has been a life saver and makes regular greasing less frustrating. I absolutely hate using grease gun cartridges and hand pumps. Always messy and lots of problems with grease squirting out of every orifice except where I want it. I've hated every grease gun I've owned until I switched to the pail pump.
   / The Great Grease Gun Coupler Showdown #74
I have a battery powered Lincoln, liked it better after I put a LockNLube on it:
My favorite is a high pressure lever gun. Replaced the pipe with a hose and a LockNLube. Just recently added another hose.
With the longer hose, I can put the gun against my chest with the hose pointing down and locked on a zerk that won't take grease, then pull the lever with both hands, allowing the gun to reach it's 10K psi rating. So far the grease has always gone in:
   / The Great Grease Gun Coupler Showdown #75
I broke down and got the DeWalt 20V grease gun. I have high expectations based on the recommendations here.
Thanks, everyone.
CRAFCO INC. MAGNUM PORTABLE SPRAY INJECTION PATCHER (A54756)
CRAFCO INC. MAGNUM...
2019 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A52377)
2019 Allmand Bros...
2019 John Deere XUV560E Utility Cart (A53421)
2019 John Deere...
Estate Equipment Auction 9/27/2025
Estate Equipment...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A55302)
2022 New Holland...
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A52706)
UNUSED CFG...
