Tractor detonates IED while mowing in PA...
   / Tractor detonates IED while mowing in PA... #11
My completely uninformed guess is that Tannerite might be involved.
Steve
Doubt it. Tannernite needs to be struck at high velocity from what I've heard. I believe pistol rounds and 22lr don't do it in general.
   / Tractor detonates IED while mowing in PA... #12
Hitting with a mower just might do it....
   / Tractor detonates IED while mowing in PA... #13
A bit of research says 2000fps. a brush hog doesn't hit even close to that speed. It would be the loudest mower in existance if the blade tips were that far above the sound barrier.
   / Tractor detonates IED while mowing in PA... #14
Not going to research and not going to put a mower on top of one to find out...:thumbsup:
   / Tractor detonates IED while mowing in PA... #15
Mower blade speed is measured at the tip. Maybe someone (Bruce) can get us some "facts". I think you'll be shocked by the numbers. :)
   / Tractor detonates IED while mowing in PA... #16
Might want to look a little more unto mower blade tip speed. Most mowers are in the 13,000-16,000FPM range.
Bush Hog lists 14,632 FPM,15,497 FPM and14,307 FPM as the tip speeds of their 4, 5 and 6 foot Razorback series rotary cutters: Razorback Series Cutters
Aaron Z
   / Tractor detonates IED while mowing in PA... #17
Aaron Z
Note his research turned up xxx feet per second, not xxx feet per minute.
Still, I think the mass of the blade versus the mass of a bullet has something to do with it.
   / Tractor detonates IED while mowing in PA... #18
Aaron Z
15,000 fpm = 250 fps. That is a fair bit shy of 2000 fps
2011 Peterbilt 337 Hydro Excavator Truck, VIN # 2NP2HN7X6BM130882 (A54865)
2011 Peterbilt 337...
New/Unused Easy Clean Hot Water Pressure Washer (A54865)
New/Unused Easy...
2016 Ford F-250 Ext. Cab Pickup Truck (A55788)
2016 Ford F-250...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATE (A54757)
UNUSED LANDHONOR...
2006 JLG 2630ES ELECTRIC SCISSOR LIFT (A52705)
2006 JLG 2630ES...
2008 FORD F450 SERVICE TRUCK (A54607)
2008 FORD F450...
