Tractor detonates IED while mowing in PA...
   / Tractor detonates IED while mowing in PA... #11
My completely uninformed guess is that Tannerite might be involved.
Steve
Doubt it. Tannernite needs to be struck at high velocity from what I've heard. I believe pistol rounds and 22lr don't do it in general.
   / Tractor detonates IED while mowing in PA... #12
Hitting with a mower just might do it....
   / Tractor detonates IED while mowing in PA... #13
A bit of research says 2000fps. a brush hog doesn't hit even close to that speed. It would be the loudest mower in existance if the blade tips were that far above the sound barrier.
   / Tractor detonates IED while mowing in PA... #14
Not going to research and not going to put a mower on top of one to find out...:thumbsup:
   / Tractor detonates IED while mowing in PA... #15
Mower blade speed is measured at the tip. Maybe someone (Bruce) can get us some "facts". I think you'll be shocked by the numbers. :)
   / Tractor detonates IED while mowing in PA... #16
Might want to look a little more unto mower blade tip speed. Most mowers are in the 13,000-16,000FPM range.
Bush Hog lists 14,632 FPM,15,497 FPM and14,307 FPM as the tip speeds of their 4, 5 and 6 foot Razorback series rotary cutters: Razorback Series Cutters
Aaron Z
   / Tractor detonates IED while mowing in PA... #17
Aaron Z
Note his research turned up xxx feet per second, not xxx feet per minute.
Still, I think the mass of the blade versus the mass of a bullet has something to do with it.
   / Tractor detonates IED while mowing in PA... #18
Aaron Z
15,000 fpm = 250 fps. That is a fair bit shy of 2000 fps
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A55301)
Michelin CARGOXBIB...
2016 Ford Transit 250 Cargo Van (A53422)
2016 Ford Transit...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55301)
NEW HOLLAND 706 30...
2020 CATERPILLAR 299D3 XE SKID STEER (A52705)
2020 CATERPILLAR...
