DC12 volt cigarette lighter socket placement
   / DC12 volt cigarette lighter socket placement #1
sevenvalleys
Member
2018 Massey Ferguson GC1705
Hey folks
Has anybody ever added an DC 12 volt cigarette lighter socket on there GC series tractors . Just curious where the best placement would be ?
This should be a standard option in my mind , but I am thinking of things such as phone charging and plug in strobe lights for snow removal etc.
Thanks for any feedback
   / DC12 volt cigarette lighter socket placement #2
I installed a double socket on the flat spot right behind the seat, there is an extra key on power source wire on the side of the top link holder bracket. I just used a good quality lock and loop. I plug my phone in and put the phone in the cup holder.
Sounds like you got a good power source thats convenient for that location . I'll check it out and most likely go the same route .
Thanks for the info .
   / DC12 volt cigarette lighter socket placement #4
If your looking at the back of the tractor, there will be a a little white wire taped with a single plug in, run your ground wire to a bolt near the wheel well )a foot away) and your all set. You can also mount it to the you rops using the same power source.
My 2018 GC1705 Has green and black wires , one male and one female end which appears to be spares . They were taped to the black plastic wire protector sheath which goes up into the right side ROP lights . One tests hot and the other is probably ground wire .
   / DC12 volt cigarette lighter socket placement #6
Ditto...
Check image on page 4-22 of owners manual and its item 18 in wiring diagram, page 4-24...
Dale
205196 (A52706)
205196 (A52706)
2010 Honda Accord Sedan (A59231)
2010 Honda Accord...
Mini Skid 6 Way Blade (A56438)
Mini Skid 6 Way...
2014 Chevrolet Impala Sedan (A59231)
2014 Chevrolet...
2020 INTERNATIONAL MV607 26 FT BOX TRUCK (A59905)
2020 INTERNATIONAL...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A56438)
2016 KBH...
