2555 HST/Cab
   / 2555 HST/Cab #11
I like it. I have been trying to figure out a way to mount a tool box on my 2538. You just showed me how! Thanks!
   / 2555 HST/Cab
Glad to have helped.
   / 2555 HST/Cab #14
I'd put one on my tractor if only I could locate the sky hooks to hang it from on my open station.
You need those dorky glasses they used to sell with the mirrors on each side..... :) [ I don't know if I used 'dorky' correctly, but I am TRYING to be ' with it ' ... ]
   / 2555 HST/Cab #15
There's a thought. LOL I just haven't sit down and put my mind to it yet. I'd probably come up with some camera thing just to make it geeky-techie. I had about six of em on my rock crawler, I do'n need no ah stinkin spotters.
   / 2555 HST/Cab
2FE302F3-55B9-4F9D-9F23-6DEF4642965C.jpegOr could use the mini mirror like bicyclists mount on their helmets, lol.
   / 2555 HST/Cab #17
View attachment 561862 I知 6?? and this pic I知 leaning back close to the window to get the angle. When I知 sitting normal I can just glance up to see what I知 after. I do get just the top of my head in the view, but not much. That may change after I raise the seat 2-3?
Thanks! I'm 6' but have raised my seat up 3" already so I'm probably right now in the same range as you are before you raise your seat up.
   / 2555 HST/Cab #18
I thought about mounting a back up camera on mine so I don't have to turn around while snowblowing but haven't done it yet.
   / 2555 HST/Cab #19
Well there's enough of them out there. The trouble is seeing the display with the glare of the sun on it and keeping it somewhat protected on an open station tractor. A glare sheid should help some in sunlight but it won't be a complete solution. Remember a dinky little display is less likely to be of any use. The dynamic range of the camera and display can be problematic as well. Keeping the camera pointed somewhat down and using a lens shade should help a little bit.
   / 2555 HST/Cab #20
I put this 50 Cal. box on awhile ago. Works great. I have another one in going to mount on the other side.IMG_20180708_160649.jpeg
2024 Isuzu NRR 24ft Box Truck (A50323)
2024 Isuzu NRR...
2008 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51242)
2008 CATERPILLAR...
2020 Bobcat T76 R-Series (A47384)
2020 Bobcat T76...
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
2010 Lincoln MKS Sedan (A50324)
2010 Lincoln MKS...
CASE 580M SERIES II TURBO BACKHOE (A51242)
CASE 580M SERIES...
