2555 HST/Cab
   / 2555 HST/Cab #11
I like it. I have been trying to figure out a way to mount a tool box on my 2538. You just showed me how! Thanks!
   / 2555 HST/Cab
Glad to have helped.
   / 2555 HST/Cab #14
I'd put one on my tractor if only I could locate the sky hooks to hang it from on my open station.
You need those dorky glasses they used to sell with the mirrors on each side..... :) [ I don't know if I used 'dorky' correctly, but I am TRYING to be ' with it ' ... ]
   / 2555 HST/Cab #15
There's a thought. LOL I just haven't sit down and put my mind to it yet. I'd probably come up with some camera thing just to make it geeky-techie. I had about six of em on my rock crawler, I do'n need no ah stinkin spotters.
   / 2555 HST/Cab
2FE302F3-55B9-4F9D-9F23-6DEF4642965C.jpegOr could use the mini mirror like bicyclists mount on their helmets, lol.
   / 2555 HST/Cab #17
View attachment 561862 I知 6?? and this pic I知 leaning back close to the window to get the angle. When I知 sitting normal I can just glance up to see what I知 after. I do get just the top of my head in the view, but not much. That may change after I raise the seat 2-3?
Thanks! I'm 6' but have raised my seat up 3" already so I'm probably right now in the same range as you are before you raise your seat up.
   / 2555 HST/Cab #18
I thought about mounting a back up camera on mine so I don't have to turn around while snowblowing but haven't done it yet.
   / 2555 HST/Cab #19
Well there's enough of them out there. The trouble is seeing the display with the glare of the sun on it and keeping it somewhat protected on an open station tractor. A glare sheid should help some in sunlight but it won't be a complete solution. Remember a dinky little display is less likely to be of any use. The dynamic range of the camera and display can be problematic as well. Keeping the camera pointed somewhat down and using a lens shade should help a little bit.
   / 2555 HST/Cab #20
I put this 50 Cal. box on awhile ago. Works great. I have another one in going to mount on the other side.IMG_20180708_160649.jpeg
McDon 75D Flex Draper Head (A52349)
McDon 75D Flex...
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
KEESTRACK K6 SCALPING SCREENER (A51242)
KEESTRACK K6...
Unused 2025 CFG Industrial QNT45 Mini Excavator (A50322)
Unused 2025 CFG...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
John Deere 920 Platform (A50514)
John Deere 920...
