Hay Making Equipment: What Size Tractor?
   / Hay Making Equipment: What Size Tractor?
Nope, not enough weight to that tractor. Can you give us an idea of what you want to spend on just the tractor?
Thanks for the helpful feedback. We were thinking 10K, but the feedback on this site is not encouraging that price point. Hmmmm. Well, I’d rather know now than be surprised later, or spin wheels, or buy a machine that’s not up to the job.
   / Hay Making Equipment: What Size Tractor? #22
10 grand will certainly buy you a decent heavy tractor with 50 hp. Keep your eyes open for a John Deere 2010,2020,2030, Ford 5000 series, a lot of times you can find one of these gems for 6 or 8 grand is good shape, there heavy, strong and easy to fix, if you find something post it here and we will be happy to help. I hate to see people buy the wrong equipment for the task at hand.
   / Hay Making Equipment: What Size Tractor? #23
I like my 560 farmall and it would make a dandy haying machine..........its got plenty of power for such work as well as weight and GREAT brakes - I have stopped some very heavy load of logs on my 18foot flatbed and lugged them up some very large hills, I do have near new tires on it though.
Its a diesel and sips fuel..........I grew up on a 400 farmall and it was a great tractor as well, it would have plenty of power and be in that same price range, they are easy to fix as well. I did all of our mowing with an old JD sickle mower - I know most have moved on from those but they were great and never gave much trouble for me even as a rambunctious kid who didn't know what he was doing.
too bad you aren't closer, we have a ford sickle mower and I am going to sell my 560 as I just traded up to a 706 - and my 560 is well under your price range - 6500 for it and it needs NOTHING.....so good deals are out there just keep your eyes peeled.
I totally agree with all that atsah had to say and have survived wagon spills, wet hay, hot days, barns so thick with dust u could hardly breathe, burning hot belts, tying that was not right, bales that weighed WAY too much, falling bales from elevators, horses with an attitude, and the frustrating day of breakdown after breakdown after rain shower after rotting hay after people that don't show up after checks bouncing after etc................
but when the snow is flying and you are flaking hay and feeding like he said, its a great feeling to know you did it and provided for your animals and family
   / Hay Making Equipment: What Size Tractor? #24
Hay baling equipment "is one of the most dangerous types of farming equipment."
S-80
National Ag Safety Database - National Ag Safety Database
Also quite expensive. You might want to run the numbers on that. You can usually work out an arrangement for someone to bale your hay and they keep part of it. Which makes more sense financially?
You're going to get very different advice from people who are experienced with heavy tractors on mostly flat land vs folks newer to the rural life, and especially those with hilly property. I think a lot of flatlanders have no idea what it's like in our kind of terrain. For example, if your WV land is hilly, an older Farmall may be risky:
If you're not mechanical, you'll need to learn all that unless you have shop nearby, especially with used equipment. Again, some of these folks with decades of experience wrenching on machines don't seem to understand how clueless we nonmechanical types are about this stuff.
Worries me a little to hear of a newbie wanting to take up haying, especially on hilly property, and especially with older equipment, which often lacks safety features. Have you ever been around haying equipment when it was running? I have (a lifetime of horse obsession and hanging around farms and barns) and I truly admire folks who can run this equipment. It is very intimidating.
Of course if your life's dream is to take up haying, do your research and go for it.
   / Hay Making Equipment: What Size Tractor? #25
A newbie city slicker might need 4wd that is heavy however if a person has common sense they would do fine with any 2wd 560 or 20 series deere or any wide front in that weight range - the one you have pictured is a narrow front tractor - there is no way I would recommend a narrow front tractor for any kind of ground and work that is NOT level - that spells trouble - I grew up with a narrow front JD model B and a Farmall 400 with a narrow front, the 400 even had a koyker Super K loader on it. I have traversed all kinds of hills and loaded hay and hauled manure with that loader and narrow front and if a person is careful and uses their noggin you will do fine on uneven ground/hills - HOWEVER - I didn't try things that were questionable that's where people make their mistakes - it only takes once - there were no such things as 4wd tractors back in the day and the ones today are light weight so to recommend a 4wd tractor would be overkill and would likely be out of their price range that is affordable in that hp tractor. Weight is important - Example...............a 2wd truck/tractor at a tractor pull can out pull a 4wd pickup due to weight and tire size, your 2wd tractor in that age/weight range is going to have a larger foot print and the weight distribution is different on a rwd tractor - for their price range they are going to have to go smaller/lighter/less hp to go 4wd. I would not recommend that for them. 560 left side reduced 50 percent.jpg560 front lights on.jpg
   / Hay Making Equipment: What Size Tractor? #26
Yup a big ole International would do the trick as well, I like them also..
   / Hay Making Equipment: What Size Tractor? #27
Hi,
We are thinking square bales, because there is a market here for them among horse people, and they are easier for us to handle.
Nobody has commented on this.
Yes, horse people like the square bales as they're easy to break apart and feed to individual horses. ....but easier to handle?
Maybe so, maybe not. That should be considered.
Yes, easier for a person to handle a square bale, but remember you personally have to handle each one 4-5 times before it gets fed, and there's a lot more of them to handle. And you'll be doing it on the hottest days. And you'll need (multiple?) special wagons, and probably hired help to unload them and hay elevators to get it in the barn. Those cost a lot more then a set of round bale spears for the tractor.
   / Hay Making Equipment: What Size Tractor? #28
nice catch cody..................I fed my horses for 15 yrs plus with all round bales and a skid steer. I could buy bales for good money here in Missouri way cheaper than I could ever have purchased all the hay equip especially since I already had the tractor - to have someone bale property is reasonable around here as well, some work on shares while others work on per bale $$ if you want to keep it - definitely an option - to keep horses from gorging themselves my daughter and I used weight tapes and monitored time in the lot to keep them fit and not fat.
horses are a money pit but my kids were worth it!!!! I grew up around them and have had singles/teams to drive with wagons so been through it all pretty much. per Winston Churchill, the outside of a horse is good for the inside of a man - if you understand that you can understand the price is worth it.
   / Hay Making Equipment: What Size Tractor? #29
Square bales are more valuable than round bales to people that don't own a tractor to lift round bales, yes it's a lot of work but they have there advantages. My brother sells a lot of hay to people that don't have a tractor nor do they have the money to buy large amounts of hay, horse people have more use for square bales because they can be stacked, moved by anyone that can lift 40lbs and it is less likely for them to have a high moisture content, round bales in this part of the country are used for cattle, they can digest them even when there is mold present. Round bales are left in a pasture for them to feed on for days on end.. Horses can get bloat and or heaves if the hay has even a small amount on moisture in it.
   / Hay Making Equipment: What Size Tractor? #30
not debating, just stating fact - I have had over 20 head of horses at times, fed them for 15 years in a wet Missouri climate, moldy, muddy, had a john deere A for 7 of that to move my bales with so it doenst take much of a tractor to move them around - I also kept them in the pasture and fenced around them to restrict and deal with when muddy since sometimes it was difficult to move them on muddy hills - SO - yes very many advantages to squares but I have NEVER in all my life had any issues with sick horses - other than one got colic in the summer and two jugs of mineral oil and he was fine after a couple of days and lots of walking around. Vet said grass was too dry and he wasn't drinking enough was the cause. I have heard every excuse in the book around moldy hay, round bale waste, but honestly - I would do it the same all over again, round bales are less time consuming, less expensive, less hassle and no one could ever convince me that it makes horses sick I haven't seen it or experienced it. All my horse people around here feed rounds - only the prissy high end people with money to burn that have less sense us the small squares LOL - I love them as some are my dear friends so we kid around a lot about it every fall when we are getting ready for winter and stocking up.
my daughters horses ran/performed just as well or better than their spoon fed high end equine. ;-)
but to stay on track and their desires of squares, I would stick with a heavy 2wd tractor vs a light 4wd every time -
Kubota M5-111 (A53317)
2017 Bobcat T450 Compact Track Loader Skid Steer (A56857)
2017 Bobcat T450...
24ft T/A Flatbed Equipment Trailer (A55788)
24ft T/A Flatbed...
WHIRLPOOL WASHER & KENMORE ELITE DRYER (A54757)
WHIRLPOOL WASHER &...
2013 PETERBILT 389 (INOPERABLE) (A58214)
2013 PETERBILT 389...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A56435)
LIKE NEW 2023...
