Fellow Kubota RTV900 owners / mechanics - H E L P P L E A S E
/ Fellow Kubota RTV900 owners / mechanics - H E L P P L E A S E
I didn't say it was a "good idea", nor anything about paying for any repairs; it was a suggestion. Guess you missed the part about SCHEMATIC? If your experienced with your VOM, you should have no difficulty tracing through the limited number of devices in the starting circuits with it to identify what's knackered.
If I DID have a properly functioning RTV900, I wouldn't be too likely to start disassembling and/or unplugging stuff to compare my voltages betwixt and between to yours just to see what might be different! But it seems like in an extreme effort to help you out without you having to spend anything for repairs, ruffdog actually HAS! And it still hasn't helped you any. Just what do expect those on an internet forum to do?
You might consider borrowing or renting a trailer which might allow you to haul your RTV to the dealer or some other service shop. That might only "waste" $50 or so.
Thanks for the kind advice. The RTV doesn't start. Thanks again for all your help.
Well again thanks. I have bought a new Gel battery, a new starter and two switches. Does kind of help your comments if you read what was in the comments preceding when you are criticizing! Once again, thanks for all the help. It was most insightful!
/ Fellow Kubota RTV900 owners / mechanics - H E L P P L E A S E #83
Easy now. :D
/ Fellow Kubota RTV900 owners / mechanics - H E L P P L E A S E #85
G'day after reading your volt meter results and looking at the wiring diag posted I am a bit confused by your results as I see it there is no power to the relay until your are in the start pos, do you have a test light? I find these can be less confusing than a vm.
The way I read the w/diag in the start pos you should have power to the BW the RL ( hard for me to see on diag but I think this is right ) and on the BY wire which should go to your starter.
The BW wire goes from the back of the ign switch and feeds the s/switch and the power into the relay
The RL wire should be the pull in for the relay
The BY wire is the feed from the relay to the starter
And the B wire is the earth ( ground) for the relay coil
Can you make a jumper wire up to jump the BY and the BW wires and try to start?
Also with your ohm meter check the B wire has a good path to earth (ground)
If it does crank with the jumper installed then remove jumper and check to see if you have power to the RL wire when your are in the start position if all this checks out ok then you have a dud relay
Hope this helps
Jon
Well thanks all. I have now replaced the battery, the starter and all the safety switches. Still no progress. That leaves only one thing since jumping the BW-->BY wire lets me start it. It has to be critter damage. My Kubota dealer will not fix the wiring, they will only replace whatever has been damaged. However, My Mahindra dealer will repair the damage to the wiring so next Wednesday it goes to the Mahindra dealer. Again thanks to all for helping me, teaching me and helping! Stu
/ Fellow Kubota RTV900 owners / mechanics - H E L P P L E A S E #87
Bummer. Sorry this has been such a hassle.
Sounds like the Kubota dealer only wanted to replace damaged components rather than do a repair of existing wiring?? :(
What they are saying is that the potential liability of repairing a wiring harness is too great. Whilst I don't agree, my Mahindra dealer is stepping up and doing the right thing. And they have on site service if needed and it is a modest charge. The Mahindra dealer is great, to say the least!
Thanks and make sure that you have a great day!
/ Fellow Kubota RTV900 owners / mechanics - H E L P P L E A S E #89
Good luck and please share the conclusion to your troubles. My RTV900 is down right now with serious transmission troubles and have had zero luck finding help searching online.
/ Fellow Kubota RTV900 owners / mechanics - H E L P P L E A S E #90
Any solution to this problem? My RTV900 is doing essentially the same thing, but with a slightly different twist to it. Just hoping there was a solution to this problem.
I am sorry for not following up. It kind of got to be a hassle since nothing I replaced worked except now all those parts are new. What I did was take it to my Mahindra dealer in Tucson who in effect went through all the wiring and taped it up where it needed it, replaced/revinyled the seats and gave it a complete lubrication service. It is basically new again. I put on some side mirrors and went to TSC and bought some LED lights attached to the roof that shine out over 700 feet and is really is basically new. It really wasn't that expensive to get it running again doing that. And the Mahindra dealer guaranteed their work.
The issue(s) were chew areas in several key parts of the wiring. The manufacturers are using wiring that attracts chewing and I don't park it there anymore! This is the desert and it is what it is! Thanks for the question!
/ Fellow Kubota RTV900 owners / mechanics - H E L P P L E A S E #92
I knew there was a reason you were not having 12v on the wires that should have it. Glad you got it going!
/ Fellow Kubota RTV900 owners / mechanics - H E L P P L E A S E #93
Now you need to put a lift kit on that and replace the front differential with a limited slip unit so you can be bada$$ and outrun the RZRs that come along. :laughing:
/ Fellow Kubota RTV900 owners / mechanics - H E L P P L E A S E #94
After reading through this and other threads I checked battery voltage --- it is a one year old NAPA replacement for the original Kubota battery -- and it measured 12.3 volts. I thought it was unlikely that it was the battery, but I went to the Kubota shop and bought a new battery and installed it. I turned the key and it started :). Here is the history of my problem:
I experienced some intermittent starting problems just prior to the RTV900 being taken in for service. I would turn the key and there was no cranking sound, no dash lights, nothing. After various intervals --- sometimes a day, sometimes several days, sometimes an hour -- I tried starting again and the vehicle would start. I would use it for various tasks and then the intermittent start problem reoccured. Kubota service found no problems.
After the vehicle was returned from service, I used it for several hours and then after dumping a load of rocks and the bottom of my driveway, it would not start. At first the symptoms were similar to past starting problems only there was a buzzing sound from the engine compartment if I turned the key hard to the off position. This would happen sometimes and not others. Then after one starting attempt and buzzing occurrence, when I turned the key the dash lights came on but still no start. After this, with each start attempt the dash lights came on, the horn worked, but the RTV still did not start.
While the vehicle has started just fine since battery replacement, I am not sure there isn't some issue with the ignition switch and I may replace that as "just in case" insurance: getting stuck in bad spots and having to be towed is its own problem and cost.
Anyway, an apparently bad battery was my problem for the starting problem. I would not think that a year or so old battery would be the issue, but replacing it did solve the problem.
/ Fellow Kubota RTV900 owners / mechanics - H E L P P L E A S E #95
For clarity, I'm Old School. Back in the day, batteries worked if they had 12V in them. That seems to not be the case now. Measuring voltage on a sedentary battery doesn't tell you much. What needs to be measured is load draw. I recently replaced $730 in batteries on a JD road grader. Both measured 12V. Grader would not crank. Replaced batteries, problem solved. I didn't have the ability to measure load draw. Frustrating, but at least you solved a problem. :)
/ Fellow Kubota RTV900 owners / mechanics - H E L P P L E A S E #96
A battery with a bad connection, like the cable, may read good battery voltage but won't allow enough current to turn the starter. It can even be an internal issue with the battery its self.
/ Fellow Kubota RTV900 owners / mechanics - H E L P P L E A S E #97
this is a good point and I thought that maybe the cable connections were too loose, but I don't get how the intermittent starting would be affected by that. Anyway, it works now and I probably will not be the last person with this type of issue so thought it was worth adding my experience to this discussion....
/ Fellow Kubota RTV900 owners / mechanics - H E L P P L E A S E #98
Electrical trouble shooting 101: Always start with a known fully charged battery. The national chain auto parts stores will load test your battery for free.
A 12 VDC flooded cell battery that measures 12 v is only 50% charged. Sulfation and other internal degradation can cause a battery to indicate sufficient voltage, but the battery will not put out sufficient current to start an engine.
/ Fellow Kubota RTV900 owners / mechanics - H E L P P L E A S E #100
If you have "a gear extending" when you try to start, I assume this is the starter gear being extended by the starter solenoid to engage the flywheel. If it is just extending, but then nothing else happens, it likely that the starter solenoid armature is also designed to close the circuit of a high-amperage switch in the end of the solenoid case that supplies starting current to the starter motor, but it is NOT.
You first need to be sure that you have good voltage and clean connections from the battery to the large/heavy solenoid collection. Sounds like you already did this. So since you still have no joy, either the "switch" in the solenoid is not working due to having its contacts being burned/corroded, OR that the starter motor itself is knackered. Usually easiest and cheapest to replace the solenoid alone first, if it is even available separately. If you have higher hours, might not be too much more and be a good idea to replace the starter/solenoid assembly. OR, most any decent automotive starter/alternator repair shop can rebuild it for you for much less than new.
Can anyone email me a drawing for connecting a Single Pole Single Throw (SPST) Relay in the starter solenoid circuit of a 2006 Kubota RTV 900 utility vehicle? Please email drawings to my e-mail address: albarrs (at) wfeca (dot) net... THANKS!
Al Barrs
15200 (A56857)
15200 (A56857)
2003 CASE 590 SUPER M BACKHOE (A60429)
2003 CASE 590...
CASE 450CT SKID STEER (A60429)
CASE 450CT SKID...
2012 Chevrolet Van (A55973)
2012 Chevrolet Van...
UNUSED SDLANCH SDLGC100 ELECTRIC GOLF CART (A60430)
UNUSED SDLANCH...
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
