normde2001
Elite Member
- Joined
- Mar 10, 2002
- Messages
- 4,159
The Hoye link you show is the Cat 1 side link w 3\4" hole, same as for cat 1 YM2000. The cat 1 toplink also has 3/4" hole.
This plastic toolbox on the qhitch is a strange one, it has rods sticking out beneath that were easy to wire to the qhitch. I meant this for a one day project but its been on there for a couple of years now. Real handy for lynch pins etc.
I'm going to weld a metal ammo can onto the qhitch in the same place when the plastic toolbox falls apart.
There are a couple of things to consider at this location: don't block the radius needed for turning the top link length adjuster. And don't block access to reach in and connect an implement pto driveshaft.
In theory the geometry should lift another inch or so. In practice - not noticeable.... the quick hitch, have you found that it helps lift implements higher off the ground?
