Big Barn
Super Member
- Joined
- Aug 20, 2013
- Messages
- 7,047
- Location
- Victoria, B C
- Tractor
- More than 40 over the years. Ten at any one time. Mostly Ford and New Holland
I picked up this high lift manual pallet jack this morning. It’s an older model but “low mileage” as it was only used in the home garage of a heat pump installer. (and only 10 minutes away from my house)
It has 30” of lift with a 2200# capacity and can only be used with an open bottomed pallet. (No bottom boards). Probably most commonly used for order picking heavy boxes etc.
I figured it would be handy to raise heavy stuff to work bench, weld table, hydraulic press bed height. I might try to find a used mag/aluminum loading dock plate to use for rolling small garden tractors or mowers onto for servicing.
Or a 4’x5’ welding table. There’s a whole realm of possibilities for
it’s use. I’m sure some of you could come up with great applications for your own situations. Ideas???
Here’s a pic of it raising my 4’x8’ welding table. This is for demonstration purposes only.
I have a shop forklift but for $100 I didn’t think I could go wrong.
