Leaky male hose end
   / Leaky male hose end #1
Wakey
Madison Georgia
John Deere Z915B Zero Turn 54 Deck
Is there ANY WAY to fix this? I twisted on the nut to no avail. Some times it gets worse, sometimes nothing changes. One thing it does not do is fix the leak. :laughing:
Look, I know lots of people have lots of real problems but if there is a way where I could put water on the beds without filling my shoes with water, that'd be great. :thumbsup:
In the past I've used lots of menders with varying degrees of success. I use 3/4" hoses. I've used these before httphttps://www.amazon.com/SOLID-Garden-Repair-Mender-Stainless/dp/B01M0Y1ZPW/ref=redir_mobile_desktop?_encoding=UTF8&dpID=61-S4NLhUQL&dpPl=1&psc=1&refRID=74HPCCMCWYR4P7989WBB&ref_=pd_aw_sim_86_1 and they work OK. The main problem I have with this mender is the nut on the hose clamp. It happily will shred your hand while using the hose. As I age, this will just get worse!
The plastic kind with a screw on each end, simply don't last.
OK, so this is the part where someone tells me of a magical fix for my hose. Bang it with a mini sledge? Weld it?
Does anyone have a recommendation for menders for 3/4" hose?
Forgot, here are the pics.. The arrows show where the leak is from.
   / Leaky male hose end #3
I just tape up the hose clamp so it wont bite me.
   / Leaky male hose end #4
When I first read the title of the thread, I incorrectly read it as "Leaky male horse end" and I was really wondering what it was about.
I just call the vet for that sort of thing. :laughing:
These work better than the metal ones you crimp on and I only use the Gilmore ones, they come in other sizes as well.
Amazon.com : Gilmour Metal Male End Hose Mender 5/8in - 3/4in : Garden Hose Parts : Garden & Outdoor
Ritothebull, thanks for the tip. I don't know if I've used that connector before but in the past when a mender says it works on 5/8 and 3/4, the collar does not fully seat on the hose. I did see where people mentioned using hot water, I'll give it a shot. Someone else said that you can clamp the couplings together to seat the screws.
Have you used this on a 3/4 hose?
   / Leaky male hose end #6
If we live long enough, many of us will experience a form of this problem. The clamp on hose fix looks promising.
   / Leaky male hose end #7
I tried the Gilmore clamp-on ones...it hurt like heck...but my wife thought it was an improvement :shocked:
   / Leaky male hose end #8
I have used them and their nylon ones as well, sometimes it may take a bit of work to strech the hose over them, if you put it in a vise than it's easier to push the hose on.
   / Leaky male hose end #9
Heat the end of the hose to be replaced in hot, hot water, it will go on.
2015 KENWORTH T800 (A52472)
2015 KENWORTH T800...
2018 FORD F-150 (A52472)
2018 FORD F-150...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2007 Chevrolet C4500 4x4 Dump Truck, VIN # 1GBE4C3247F411826 (A51572)
2007 Chevrolet...
2015 Kubota MX5200F 55HP Loader Utility Tractor (A51691)
2015 Kubota...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
