Leaky male hose end
   / Leaky male hose end #1
Wakey
Madison Georgia
John Deere Z915B Zero Turn 54 Deck
Is there ANY WAY to fix this? I twisted on the nut to no avail. Some times it gets worse, sometimes nothing changes. One thing it does not do is fix the leak. :laughing:
Look, I know lots of people have lots of real problems but if there is a way where I could put water on the beds without filling my shoes with water, that'd be great. :thumbsup:
In the past I've used lots of menders with varying degrees of success. I use 3/4" hoses. I've used these before httphttps://www.amazon.com/SOLID-Garden-Repair-Mender-Stainless/dp/B01M0Y1ZPW/ref=redir_mobile_desktop?_encoding=UTF8&dpID=61-S4NLhUQL&dpPl=1&psc=1&refRID=74HPCCMCWYR4P7989WBB&ref_=pd_aw_sim_86_1 and they work OK. The main problem I have with this mender is the nut on the hose clamp. It happily will shred your hand while using the hose. As I age, this will just get worse!
The plastic kind with a screw on each end, simply don't last.
OK, so this is the part where someone tells me of a magical fix for my hose. Bang it with a mini sledge? Weld it?
Does anyone have a recommendation for menders for 3/4" hose?
Forgot, here are the pics.. The arrows show where the leak is from.
   / Leaky male hose end #3
I just tape up the hose clamp so it wont bite me.
   / Leaky male hose end #4
When I first read the title of the thread, I incorrectly read it as "Leaky male horse end" and I was really wondering what it was about.
I just call the vet for that sort of thing. :laughing:
These work better than the metal ones you crimp on and I only use the Gilmore ones, they come in other sizes as well.
Amazon.com : Gilmour Metal Male End Hose Mender 5/8in - 3/4in : Garden Hose Parts : Garden & Outdoor
Ritothebull, thanks for the tip. I don't know if I've used that connector before but in the past when a mender says it works on 5/8 and 3/4, the collar does not fully seat on the hose. I did see where people mentioned using hot water, I'll give it a shot. Someone else said that you can clamp the couplings together to seat the screws.
Have you used this on a 3/4 hose?
   / Leaky male hose end #6
If we live long enough, many of us will experience a form of this problem. The clamp on hose fix looks promising.
   / Leaky male hose end #7
I tried the Gilmore clamp-on ones...it hurt like heck...but my wife thought it was an improvement :shocked:
   / Leaky male hose end #8
I have used them and their nylon ones as well, sometimes it may take a bit of work to strech the hose over them, if you put it in a vise than it's easier to push the hose on.
   / Leaky male hose end #9
Heat the end of the hose to be replaced in hot, hot water, it will go on.
2025 CATERPILLAR 275 SKID STEER (A52705)
2025 CATERPILLAR...
66'' root grapple (A53421)
66'' root grapple...
UNUSED Polyester Arborist Outdoor Rope (A53117)
UNUSED Polyester...
1840 (A51248)
1840 (A51248)
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
