Foam filled tires...
   / Foam filled tires...
Thanks DMW.
I'll look into local resources this week.
Still not sure if this is a good option but I've already had a flat front tire for no apparent reason. Aired it back up and it's holding with no repair.
   / Foam filled tires... #12
Solid tire are $$$$$$. Wow.
   / Foam filled tires... #13
A foam tire is solid. They値l never go flat. The disadvantage I can think of are cost, harder ride and getting the tire off when it痴 worn out.
+1. Pay particular attention to the "hard ride" part!
   / Foam filled tires... #15
Well since my CUT is top speed of 6-7 MPH and never rides on pavement I for one would not be concerned, also it is chained for winter duties.
I tried them on the front of a ZT mower that goes about that fast. Reason was I usually ran 5-6 psig in normal pneumatic tires for a softer ride and the tire to rim interface leaks down. So I bought solid tires since one worked on my wheelbarrow. Not the right choice for me.
   / Foam filled tires... #16
On my Ford 1920 when I got new tires on the front, 8.00-18 6PR R1, I had them foam filled. At least 15 years ago. Seems like tires cost $150 each and the foam was an additional $150 each. They are very heavy. Steering & ride are fine even at -10* F. The foam has saved me from many flats. Tractor loader is used mostly for rough cleanup jobs like dumpsites and transient campsite abatements. Also have foam fill on the 6 rear tires on a 15 ft. Batwing mower. Pulled lots of sharp objects from those tires - broken coil spring, piece of rebar, bottom of a broken beer mug etc. When mowing an area that looks bad I mow into it going backwards. Saves the tractor tires. Where you need protection from flats, foam is the way to go. The only downside to foam is they don/t dissipate heat. So you can't travel over about 25 MPH. Some people transport batwing mowers over the road by hitching to a the pickup and towing like a trailer. That will ruin the foam fill & tire. I drive the tractor/mower from jobsite to jobsite. Max groundspeed is ~18 MPH. Or have the equipment transported by semi. Works for me.
   / Foam filled tires... #17
I foam filled the front tires of a tractor. We have mesquite thorns and the foam fixed the problem permanently. The added weight on the front was a big bonus. Cost $250 each to get done. One of the best things done to the tractor.
   / Foam filled tires... #18
I really want to foam my mains (9.5 X 18 R3's) as they are no longer available.
Problem is no shop ever returns my Email or phone calls, getting quite frustrated.
OK some want to sell me new rims and tires ($$$) but then my fronts are 5 X 12 so I'd have to re rim and tire them as well?
   / Foam filled tires... #19
When I bought my used B26 TLB 2 years ago it had foam filled front tires. They added foam due to multiple flat tires they had been getting from punctures. The added weight in front is great for loader work, when I need extra down pressure. I think whether I would foam fill my tires in the future would depend mainly on: are punctures likely on my property and can I afford the added expense?
   / Foam filled tires... #20
I looked into foaming my fronts on the 4610 SU but got 18 plys from Gensco instead. Have any of you that foamed the fronts seen flat spots develop? I know that this is an issue on some installations. I've also heard of increased wear on the front bearings and steering components due to the added weight.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2016 Ford F-150...
30' E-Z Trail Head Cart (A59814)
30' E-Z Trail Head...
2011 Toro Workman HD Gas Utility Cart (A59228)
2011 Toro Workman...
