Cheap Start to Reloading?
   / Cheap Start to Reloading? #131
I agree with rbstern, you'd have much different results if you fired into ballistics gel. I know, not something most people even look for and very few have, but for real expansion comparisons, it can't be beat. Not that expensive either if you just mix up smaller targets, but rifles need much larger sizes.
Agreed. the gelatin is a bit spendy to make, but it is doable. I've done plenty of BG testing with handguns evaluating different ammo types. As long as you keep the BG clean, you can re-melt and re-use it. if it gets debris in it too much it can foul it.
Shoot some of the Xtreme HP, 5.6 gr CFE Pistol, 1.125", into a stack of water jugs, and a single jug full of sand, then saturated with as much water would fit. 20180810_184823.jpeg20180810_184656.jpeg
Got 0.4015" expanded in water, with 88.8gr retained weight.
Got 0.4525" expanded in wet sand, with 70.3 gr retained weight.
Also, I think at max, primers have a 'look' to them.
Couple pictures didn't upload.
I don't know if I mentioned, but I don't think Xtreme advertises them as expanding, I really just wanted to see if they would. Both shot from Hi Point 995 carbine.20180810_184533.jpeg20180810_184618.jpeg20180810_184607.jpeg20180810_184656.jpeg20180810_185433.jpeg
Went up to Waldo flea market, and picked up Lee .270 Winchester dies (Lee-270-A6) 2 die set (minus shell holder) for $8. Look to be in good shape.
   / Cheap Start to Reloading? #135
Anyone use cold mashed potatoes as a substitute for gelatin?
So, I thought after the fact, saving $16 on dies prompted me to order $60 of stuff, and still need powder and large rifle primers.
I ordered 100 EA 100 gr Varmint and 130 gr Speer (Gold Dot I think).
Powder, I'm gonna buy local, either Varget, CFE223, or maybe BL-C(2).
I've got around 40 fired brass already
   / Cheap Start to Reloading? #138
If you've never shot gelatin, try it sometime. Nice being able to cut open and see trajectory and permanent wound channel.
Loaded my first rifle rounds tonight, 100 gr Speer Varmint HPs, 48.0 gr CFE-223, 3.145", Winchester Large Rifles.
The press maybe at its max. To seat bullets, you really have to angle it just right. Hopefully the 130 gr aren't an issue. 20180816_190742.jpeg20180816_190634.jpeg
48.0 gr shot fine. I was kinda concerned about the amount of empty case, but it wasn't an issue. Wanted to build my confidence on a mild/light charge first.
BUNDLE OF GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF...
UNUSED FUTURE MINI EXCAVATOR HYD THUMB (A51244)
UNUSED FUTURE MINI...
2022 Bobcat E88 Excavator (RIDE AND DRIVE) (A50774)
2022 Bobcat E88...
2018 RoGator 1100C (A52128)
2018 RoGator 1100C...
2008 John Deere 2305 Tractor (A50514)
2008 John Deere...
2013 John Deere 2210 Accudepth Field Cultivator (A52349)
2013 John Deere...
