Kinco KMG38 Sickle Mower
   / Kinco KMG38 Sickle Mower #31
could you send me a PDF file of the manual, I recently picked up a KMG 38 at a yard sale and have no information on it, would be great if you could send me a copy of the manual,
send to rayseguin@telus.net
   / Kinco KMG38 Sickle Mower #32
Harl,
Did you get the Sickle going? I have the same problem. I'm now considering buying a new carb.
Pw
   / Kinco KMG38 Sickle Mower #34
Took the motor apart to change leaking seals on both output shafts and will also seal up the oil filler spout where it joins the motor, still no luck finding a manual, I have the Tecumsa engine.
   / Kinco KMG38 Sickle Mower #35
   / Kinco KMG38 Sickle Mower #36
Here are some pics as I removed my Tecumseh carburator. Tecumseh carburator govenor linkange connection.jpg Tecumseh throttle linkage to carburator.jpg Tecumseh Carburator air intake.jpg top view.jpg
   / Kinco KMG38 Sickle Mower #38
I may have a copy of the 3.5 Tecumseh 2-cycle motor manual, depending on the vintage, if you still have a need.
This manual covers the following basic type or model
numbers dependent on age of product: AH520, AH600,
AV520, AV600, HSK600, TVS600.
This manual covered many engines under an Old form of
Identification which will need to be reviewed as well.
TYPE / SPECIFICATION NUMBER 638-670 1398-1642 and
Craftsman 200 Series Models.
   / Kinco KMG38 Sickle Mower #39
Kinco KMG-38 V belt obtained from Tractor Supply. Correct size is 1/2 inch by 38 inches. 0.5 in by 38 inch v belt.jpg
   / Kinco KMG38 Sickle Mower #40
My Kinco KMG-38 with a Tecumseh got a replacement carburetor that I ordered online. It needed no adjustments after installation.Carburator box top view.jpg Tecumseh 3.5 hp replacement Carb.jpg
2023 LMC M40018 LOT NUMBER 176 (A53084)
2023 LMC M40018...
2018 FORD F-150 (A52472)
2018 FORD F-150...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A52748)
2018 John Deere...
2016 FORD INTERCEPTOR (A51406)
2016 FORD...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
2011 INTERNATIONAL PROSTAR PREMIUM (A52472)
2011 INTERNATIONAL...
