Backhoe Best way to get grease in a stuck fitting.
   / Best way to get grease in a stuck fitting. #1
4570Man
Super Star Member
Crossville, TN
Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
There’s 2 fittings I can’t get grease in on my backhoe on the loader. One is leaking grease around the threads but it takes firm pressure to leak so it’s not the entire problem. I can probably tighten or change the fitting and fix that one. The other one the grease gun won’t seal to, but it takes firm pressure on the gun so it’s not as simple as a bent fitting.
   / Best way to get grease in a stuck fitting. #2
A couple months ago I had a couple fittings that would not take grease in my MiniX .. I hit them for a few seconds with a small propane torch..and it worked...
   / Best way to get grease in a stuck fitting. #3
There痴 2 fittings I can稚 get grease in on my backhoe on the loader. One is leaking grease around the threads but it takes firm pressure to leak so it痴 not the entire problem. I can probably tighten or change the fitting and fix that one. The other one the grease gun won稚 seal to, but it takes firm pressure on the gun so it痴 not as simple as a bent fitting.
Replace the fitting
They are not expensive. Most will need just a few turns with a 7/16 end wrench.
   / Best way to get grease in a stuck fitting. #4
Depending on what tractor, you may have metric grease fittings, just fyi.
Another thing to try for a "stuck" fitting, is a grease needle. It basically goes on the end of your grease gun, and the needle end presses in the ball on the grease fitting, and you inject the grease in that way. Works well for forcing a stuck ball to open.
   / Best way to get grease in a stuck fitting. #5
Replace both fittings or screw the grease gun directly into the machine. Get firm pressure on the gun then move the pin that is associated with the grease port. If that dosnt work then your prety much going to have to remove that pin and clean the dryed grease/dirt out. You will only let it go that long once because greas is cheap and easy. Fighting and removing a pin because i didnt take 5min a grease a machine is alot more of a pain.
I just got the machine and the best I can tell it’s been well serviced. It’s sat for about a year though.
   / Best way to get grease in a stuck fitting. #7
lock n lube and air operated / battery powered grease gun after you replace the fitting .
A buddy has one of those. I may try to borrow it and see if it works and better for this job.
   / Best way to get grease in a stuck fitting. #9
I have one zerk out of the 32 on the back blade, tractor, FEL and grapple that just refuses. Its on the grapple - new zerk = no joy. Solution - rotate the grapple jaws to a slightly different position - zerk takes grease just fine.
   / Best way to get grease in a stuck fitting. #10
Either replace fitting or try using something like tiny punch (nail set) and press in on ball (not with hammer).. Sometimes ball just gets stick.... Learned trick working in gas station years ago when the actually did lube jobs....
Dale
   / Best way to get grease in a stuck fitting. #11
No idea how old yours is, but the old JD BH I had needed about 14 zillion zerks hit (exaggerating - prob only 13 zillion). So whenever I had any that were difficult, I swapped them. Kept a set of fittings & wrench in toolbox. Was so much better to fix it once than to struggle with same fittings over & over. Any I "fixed" by just tinkering to get it to accept grease seemed like it was a problem again next time.
   / Best way to get grease in a stuck fitting. #12
I just figured they must be full! HA HA
Recently I purchased a tool that you fill with grease then place over the fitting and hit with a hammer. Haven稚 got a chance to try it yet...
My machine is a 2011. The backhoe boom has been well greased and all took grease. The loader I don’t think was ever used and might not have been greased as frequently.
   / Best way to get grease in a stuck fitting. #15
grease behind zerk is probably hardened up. if that is the case take zerk off and blow out with air gun.
   / Best way to get grease in a stuck fitting. #16
Pull the zerk, clean the passage with brake clean and a wire then some WD, reinstall or new zerk and go,
royal pain but works the best in most cases,
also the impact type tools to my knowledge are to be filled with solvent or light oil not grease
I can handle removing the zerk. Removing the pin is a lot bigger job.
I ended up removing the pins and still haven’t got anywhere. This doesn’t have a simple hole for the grease, but it has a bushing in the cast arm. The bushing has a grease groove on both sides so there’s no direct path. I removed the grease fittings, cleaned out most of the grease, and filled the holes with Kroil oil. I’m hoping that works. IMG_4602.JPG
I finally got grease through both sides. One gave up after the kroil soaking. The other required another heating.IMG_4603.JPG
   / Best way to get grease in a stuck fitting. #20
For feature reference a lot of times a deep socket can be hammered on and slid in as the pins are being slid out and removed towards the other side. The socket holds everything lined up as you clean up the pin or bushing. Then just tap everything back in as the deep socket slides out.
2023 Kubota LX2610SUHSD MFWD Compact Tractor with LA535 Front Loader (A56438)
2023 Kubota...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A56438)
2006 Magnolia Dry...
2024 CATERPILLAR 259D3 SKID STEER (A60429)
2024 CATERPILLAR...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
2008 GMC Savana 2500 Cargo Van (A59230)
2008 GMC Savana...
