the pto pump is a prince 7gpm i used original hose to connect to pump pressure side then i capped off the power beyond sense its of no use to me. the hoe is a 3710b off a mahindra tractor i used a 10 gal fluid tank and a 3/4 hose from tank to inlet side of pump ,filter is on the return from controller to tank. the tractor is a ck20s standard with a pto hp rating of around 17hp i think, so i think the pto should handle it also i ran the PB into a bucket and tried it again and it didnt put any strain on pump but didnt have enough pressure to move the hoe around so i dont know if i could run it back to tank without more knowledge of the relief valve and how it runs.. if i could cut the flow of the PB to give me more pressure to the hoe then that might be a way to go if i could do that through relief valve dont know
