100 td
Platinum Member
- Joined
- Aug 29, 2015
- Messages
- 525
- Location
- ɹǝpunuʍop
- Tractor
- Kubota B21TLB (B21, TL421, BT751) Toyota SDK4, T116 Bobcat
When the pump is operation, hydraulic flow needs to go into the valve block on the IN or P port and it needs to exit the PB port. So when running, FULL FLOW EXITING THE PB PORT ALL THE TIME with the valves centered. When you operate a valve, flow out the PB line stops, and now goes to the allotted cylinder AND EXHAUST flow exits the tank line from the opposite side of the cylinder. When it comes to end of stroke (or relief pressure is exceeded), flow exits via the tank line via the relief valve if the valve is held, until the valve is released and then full flow exits the PB port again. Make sure you don't have PB and P around the wrong way.
