School me on old used rotary cutters
   / School me on old used rotary cutters #1
XR4140
MO
18 LS XR4140
Example: Is this worth $400?
Old Hog on CL
Im looking for a 6'+ tho....What are the pitfalls to be aware of, when looking at an old turd?
   / School me on old used rotary cutters #2
probably is worth $400 if the driveshaft is straight and the gearbox isn’t leaking oil everywhere and isn’t making a racket.
   / School me on old used rotary cutters #3
Rotary cutters take a beating...
They could have cracked decks, bent PTO shafts, skidder plates worn completely off, leaking gear boxes and or broken/chipped gears.
You just have to give it a thorough once over and it would be best if you could see it cut and lift it up to see under it.
td
   / School me on old used rotary cutters #4
Tractor Mike on youtube just did a vid on vibrations from a rotary plus a few things to look for
Run it before you buy it is all I can add
Thanks guys. Of course the guy sold his tractor and cant test it. After seeing it, looked to be gushing oil from the gear box.
   / School me on old used rotary cutters #6
I would stay clear of it unless you want to buy a new gearbox for $275.00..
   / School me on old used rotary cutters #7
Seems like the owner would pull it out, pressure wash the deck and generally clean it up before listing it. But you see this all the time on CL. I always look for things like that and a clean a garage (or whatever) in the background. I would rather buy from someone who gives a carp and how they keep their place often tells me how they keep their equipment.
   / School me on old used rotary cutters #8
It's a rugged unit and I would have no problem giving him what it's worth, I would say it's worth $250 and that's it with a gearbox leaking. last year I gave $600 for an old International 4 footer that had a new gearbox, really good rugged mower.
   / School me on old used rotary cutters #9
It is probably worth it. Cornhead grease in the gearbox and a coat of paint and you may well be fine. I would like to know that the gearbox was not history. Can you bring your tractor to the site and try it out or get him to give your $ back if gearbox is locked up?
   / School me on old used rotary cutters #10
I bought one just like that for $300 a few years back that was in way worst condition. Welded up the cracks, put a new wheel behind it, filled up the leaky gearbox with grease & painted the rust. We had just bought a piece of property that was overgrown for several years and use it behind my 49 8N Ford to clear it off. Hit a few saplings that the old tractor could barely push over, but that Bush Hog chewed them all up. Used it that one time, sold it and made a few bucks to boot. That old Hog was a tough piece of equipment. If you can get a look under it at the blades and see if the gearbox turns, I wouldn't be afraid of it, but I'd offer less and see what he says.
2017 PETERBILT 567 TRI-AXLE MID-ROOF SLEEPER (A52472)
2017 PETERBILT 567...
NEW Wolverine 72'' Skid Steer Sickle Bar Mower (A53002)
NEW Wolverine 72''...
Ford Super Duty FX4 Pickup Truck Bed (A51691)
Ford Super Duty...
PENDING SELLER CONFIRMATIONS (A52577)
PENDING SELLER...
