I would not use high temperature grease, you specifically want to use a flowable grease with the nlgi number of 0 or 00. That is commonly referred to as corn head grease.Yeah I'd want to see and hear it turned on. As mentioned fill the gear box up with a high temp grease (like used in a grease gun) and forget the leaks.
If you use regular grease like in a grease gun it will pack up on the sides and will not lubricate the gears, the flowable grease will flow back down onto the gears and will lubricate them.
Aaron Z
May just buy a cheap Countyline from TSC. Im not doing anything crazy with it. Thanks guys.
I'd much rather have the old beat up bush hog over a cheap Countyline from TSC.
I do not disagree and I like to buy quality old iron and fix it myself. Having typed that, I thought that I read that Country Line is a decent brand?
