School me on old used rotary cutters
   / School me on old used rotary cutters #11
Yeah I'd want to see and hear it turned on. As mentioned fill the gear box up with a high temp grease (like used in a grease gun) and forget the leaks.
   / School me on old used rotary cutters #12
I would not use high temperature grease, you specifically want to use a flowable grease with the nlgi number of 0 or 00. That is commonly referred to as corn head grease.
If you use regular grease like in a grease gun it will pack up on the sides and will not lubricate the gears, the flowable grease will flow back down onto the gears and will lubricate them.
Aaron Z
   / School me on old used rotary cutters #13
Aaron Z
Nope, I know of several that have run for years. We ain't talking about a lot of moving parts here.
   / School me on old used rotary cutters #14
It’s hard to judge the build quality over the picture but it appears pretty heavy duty. If it really is and isn’t trashed it’s worth $400. Of course I’d offer less. Unless you’ve looked in person I don’t know how you determined the gear box is leaking. Seals are pretty cheap. I’d make sure it has oil in it.
May just buy a cheap Countyline from TSC. Im not doing anything crazy with it. Thanks guys.
   / School me on old used rotary cutters #16
I'd much rather have the old beat up bush hog over a cheap Countyline from TSC.
Budget $200.00 WCS in repairs on the Hog worst case scenario.
The old hog looks a lot better than my beat to death John Deere 503 that I pulled several hours today.
td
   / School me on old used rotary cutters #17
I do not disagree and I like to buy quality old iron and fix it myself. Having typed that, I thought that I read that Country Line is a decent brand?
   / School me on old used rotary cutters #18
If the gearbox is good it is worth it. Looks like an older 305. Be aware that gearbox parts may or may not be available. I would determine that first.
   / School me on old used rotary cutters #19
For a lot of people they work just fine. When I bought my old International I looked at the local TSC store, If I couldn't find an older one I was going to buy a TSC, IMO they are light duty mowers but they get the job done.
   / School me on old used rotary cutters #20
The oil on the back of the gear box could be there because he overfilled it and the pressure pushed it out.
Used brush mowers around here will usually sell around $100 per cutting foot, as a guide.
If you don't feel comfortable taking a risk, or working on it...don't buy it. If you go get a new one you will get a lighter duty mower for twice the price, but hook it up and go happily mowing!
2006 KOMATSU  D41P-6  CRAWLER TRACTOR (A52576)
2006 KOMATSU...
2018 HINO CONVENTIONAL TYPE TRUCK (A52472)
2018 HINO...
2017 VOLVO VNL SLEEPER (A52577)
2017 VOLVO VNL...
378804 (A51572)
378804 (A51572)
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A52748)
2022 MAXXD BD14...
