Yanmar YM2000 Fuel Pressure/ hard starting
   / Yanmar YM2000 Fuel Pressure/ hard starting #131
Well ****, I could build one of those.
Thats what I did.
Used Thread all and machined a stout plastic insert that self centered under the liner .
The only critical part was making the liner insert big enough to catch the edge of the liner but not the parent block material.
   / Yanmar YM2000 Fuel Pressure/ hard starting #132
A buddy of mine is a certified diesel tech up at the semi dealership here in town. I値l be borrowing his hone anyway, I知 sure he can help remove the sleeves if we decide they need to be replaced.
Really would be helpful to measure the ID of the liners - the picture may be exaggerating it but there sure seems to be a lot of wear at the top .
definitely need a ridge reamer before honing if that is the direction you decide to go.
looks like things will be looking up shortly,:thumbsup:
have you had a chance to look into the price/ availability for the needed parts yet?
   / Yanmar YM2000 Fuel Pressure/ hard starting #133
Not that it makes any difference but I would suspect starting fluid caused a good bit of your catastrophe.
   / Yanmar YM2000 Fuel Pressure/ hard starting #134
Not good, good thing you pulled those piston. If had just slapped it back together, you'd be pulling it back down, wasted time and money. Probably wouldn't hurt to inspect the main bearings.
He had to, even if he just honed the cylinders, but yes glad you pulled them so that was obvious!
   / Yanmar YM2000 Fuel Pressure/ hard starting #135
It appears to, I will try honing first, if it痴 not enough then it will have to come all the way out and apart and go get re-sleeved. I was really hoping to be able to do an 妬n frame rebuild, but we will see.
yes it has liners. Hoye has them
   / Yanmar YM2000 Fuel Pressure/ hard starting #136
What痴 the best method to getting them out? I致e done several gas engines and my old Cummins, but none have had sleeves.
I think this is the thread we referred to the old Domush thread where he rebuilt an abused 336 the shade tree way and inframe like this. If we have not i just referenced it. He pulled his liners in the engine and made some sort or puller and went into detail about its construction and use.
The top is mostly carbon and oil build up, not so much wear. There is wear however down towards the bottom and middle of the bore, mainly where you can see that it looks like the piston got stuck.
As far as starting fluid being a possible cause, could be, I never used any, but the PO might have, who knows. I am going to guess that he isn’t the one who did the fancy head gasket work though.
I’ve looked up mostly everything I need, if I don’t do new injectors or sleeves, I’m at about $600. That’s including a new air filter, coolant hoses, etc.
   / Yanmar YM2000 Fuel Pressure/ hard starting #139
Seeing what the injectors cost i would use what you have. But if you want take them to your buddy and get the new nozzels and rebuild them.
   / Yanmar YM2000 Fuel Pressure/ hard starting #140
Well it was suggested by someone up the post to just put a head gasket on and slap it to gather and run it, See post 107 &109.
SCAN TO RECEIVE TEXT UPDATES (A52705)
SCAN TO RECEIVE...
Chery 7' 35 Drawer Workbench (A50120)
Chery 7' 35 Drawer...
U56 ELECTRIC FIRE PUMP (A51406)
U56 ELECTRIC FIRE...
2016 Ford F-550 Ext. Cab Flatbed Truck (A52377)
2016 Ford F-550...
2012 VOLVO BL70B BACKHOE (A51246)
2012 VOLVO BL70B...
