multi function inverter welders
   / multi function inverter welders
I wouldn’t even worry about 6010. As long as it could run 6011 you’d be fine.
It would have to be a pretty poor welding machine not to be able to run 6011.
yeah, I would take that . I just haven't see anyone make a vid of one of these machines burning a 6011 well. It may light off a few min. then go out as if you turned the power off.
I can't seem to find one that list the OCV specs
   / multi function inverter welders #22
I can't seem to find one that list the OVC specs
Just to name a few, New Miller Maxstar, ESAB 161, Thermal Arc 161STL, ESAB Rebel 215 mig,tig,stick. All around 80-90 OCV. Don't get me wrong on this whole OCV thing. I don't own or use 6011 or 6010. Nasty stuff in my book. I don't root pipe and if I have something corroded enough that it needs 6011, I clean it and use something else.
   / multi function inverter welders #23
I think I’ve only needed (or decided to use) 6011 once in the last 20-30 years.
Thanks, I'll take a look at those.
Well, most of the stuff here on the farm is nasty stuff. Cutter is rusty, disc, etc, is nasty stuff.
I use 6010 /6011 to weld up things such as this out in the field.
To be able to tig alum and steel would be just a bonus
Thanks for the info !
I didn't see a listing for the OVC listing on any of these machines I looked up.
Looks like the ESAB Rebel might be the best deal for a true multi process welder that is stated it will light up a 6010 !
I don't need it, But it even gives you a mig option with this machine
I'll have to call about this machine next week and ask some questions about this unit
Both the Lincoln and Vulcan list 6011 rods in their manual...
I guess there is no everlast welder that meets my needs.
I would think the lincoln would be the better choice, even though it is a little more money Especially if the lincoln is an IBTG machine .
If the HF machine is cheaper, may be a mosfet machine. I haven't checked either, but I intend next week to before I buy
   / multi function inverter welders #28
What are your needs? Why would Everlast not meet them? Everlast pioneered the compact multi-process units in the US and we have more experience in building them. Everlast multi units offer more features than ANY other unit on the market. The PowerMTS 221STi, and 252STi both have 6010 dedicated settings, AC/DC TIG, HF start and more. Both the 211 and 251Si will weld 6011 AND have a feature for TIG that none of the others have: HF start and out the front connections for TIG.
I guess because I got no answer from post #13
Ingersoll Rand Air Compressor (A52377)
Ingersoll Rand Air...
2015 Ford Escape SUV (A55758)
2015 Ford Escape...
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
1992 Peterbilt 377 Sleeper Cab (A55302)
1992 Peterbilt 377...
2016 Ford F-550 Enclosed Service Truck (A55852)
2016 Ford F-550...
