Well isn't this a coincidence...got on the 2538 this morning, turned the key, and click, click, click. No cranking. Having had this problem before out in the middle of a field, I figured it was corroded battery cables. Raised the hood, removed the air filter, and to my surprise there didn't appear to be hardly any corrosion around the batter terminal.
So I pulled out my volt meter, and checked the terminals themselves, on the battery, and I had plenty of juice. Then I looked at the 2 smaller cables that tie into the positive side of the battery cable, just before the terminal and they did have a fair amount of corrosion. Took them off, cleaned them up and put everything back together.
Voila! Started right up. I can't believe they get corroded so quickly. I cleaned them about 4 months ago when it happened.
Isn't there some kind of "gook" you can put on the terminals to limit the corrosion? I thought it was grease, but I'm probably wrong on that one. Would like some input from you if you've had success limiting the corrosion.
