Pawatch
Member
New member...Thanks for sharing your build! "It is a very good read"
Interested to see the fireplace you are putting in.
I thought Glulams were 2X4's or 2X6's etc glued together to make a beam. Are they both called the same thing? Or am I wrong?
Do not hit one of those 4x4 posts holding up the patio roof with your FELI thought about that for sure. I just don't want to leak or spill any oil/grease on the new concrete. My tractor does not leak anything and it may be under the covered patio for sure.![]()
Lots of names for these -- around here either "glue-lams" or "LVLs" (laminated veneer lumber). Always thin layers, 1/16-1/8" thickness. There is also a LSL (laminated strand lumber) that is sort of like OSB but for beams.
I haven't seen any commercial laminated products using two-by lumber. Certainly you can form up your own on site by sistering with bolts and/or construction adhesive. Don't think they will have the same benefits as an LVL though, due to grain, knots, etc, that reduce the allowable rating.
Update;
I have the main water line in and inspected. (passed too:laughingSorry no pictures.
Next week we'll back fill the foundation, the floor in the crawl space will be poured and framing will start.
We picked out our fire place yesterday. (wood burner) All I can say is WOW!!!I had some bad sticker shock to say the least.
It's a Quadra-fire Pioneer 2. (Although I might change to the 7100) I like the big window, really like to watch the fire burning.
Oh yeah. Around here 2x glue lams are maybe were, popular as an alternative to Douglas for beams. Cheaper and smaller dimension required by code.I haven't seen any commercial laminated products using two-by lumber. Certainly you can form up your own on site by sistering with bolts and/or construction adhesive. Don't think they will have the same benefits as an LVL though, due to grain, knots, etc, that reduce the allowable rating.
