Is this some kind of pressure relief valve?
   / Is this some kind of pressure relief valve? #21
I think I found a local supplier of Prince valves but they are closed for the day. I will try them tomorrow.
Thinking the 1/2" valve would work since it is rated for the same flows and pressures.
Isn't your valve a half-inch valve? I was thinking it was because that is what you linked to. If it is less than half inch, 1/2 inch valves should be a good upgrade.
Aaron Z
Aaron Z
Yes my valve is 1/2" but with the restrictions in the flow path I can see why there is such a large pressure loss through it. I thought / hoped the Prince valve had a clear flow path and if so then I would just get the 1/2". The pressure / flow ratings for the Prince 1/2" and the 3/4" are the same. I would have to see the valve or get confirmation that it has a clear path before buying it. The guy at PA (where I bought the valve) told me the ones they used to sell had a clear flow path.
Won't be calling Motion Canada tomorrow about the Prince valve. I forgot it was Friday and I don't think they are open on Saturdays.
John
Did some more internet searching and it appears the Prince valve does not have a clear flow path either. It also looks like the 1/2" and the 3/4" valves use the same part number for the poppet valve. Not sure if the through ports on the 2 valves are the same with different connection sizes or if the port sizes match the connection size. Looks like I may have to wait until Monday to find out.
I decided to abandon the skidsteer approach because I think there is something wrong with the auxiliary hydraulics and I don't want to screw up the machine just to use the snow blower. I am going to mount the blower on the front of the tractor and install / construct a hydraulic pack off the pto. I will start a new thread about this when I get going on it.
2011 JACK COUNTY 130BBL VAC TRAILER (A55745)
2011 JACK COUNTY...
2025 Kivel Quick Hitch Skid Steer Attachment (A55851)
2025 Kivel Quick...
CATERPILLAR 272D2 XHP SKID STEER (A52707)
CATERPILLAR 272D2...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A56138)
2015 FREIGHTLINER...
2012 Chevrolet Traverse SUV (A55853)
2012 Chevrolet...
