Cut dump trailer coupler, weld on adjustable height coupler (w/pics)
/ Cut dump trailer coupler, weld on adjustable height coupler (w/pics) #1
Sodo
Elite Member
Cascade Mtns of WA state
Kubota B-series & Mini Excavator
My dump trailer coupler was damaged a little and was difficult to get it coupled. The locking mechanism didn't want to slide into the closed/locked position. From looking at the scars below, I thik the trailer was backed over an embankment, and the ball or tongue bent the mechanism.
Anyway, I decided to replace it, AND instead of the same type, with an adjustable height coupler. Got this adjustable kit for $58 on Amazon. It's rated for 14,000 lbs.
Welded with a Miller MultiMatic 200 wire feed (portable MIG TIG Stick) on 240v.
577391d1541307185-cut-dump-trailer-coupler-weld-adj_coupler31-jpg
Cut it off with a steel-cutting skilsaw.
577392d1541307185-cut-dump-trailer-coupler-weld-adj_coupler32-jpg
577393d1541307185-cut-dump-trailer-coupler-weld-adj_coupler34-jpg
577394d1541307185-cut-dump-trailer-coupler-weld-adj_coupler37-jpg
577395d1541307185-cut-dump-trailer-coupler-weld-adj_coupler39-jpg
577396d1541307185-cut-dump-trailer-coupler-weld-adj_coupler40-jpg
Why not tie it in top and bottom?
577397d1541307185-cut-dump-trailer-coupler-weld-adj_coupler45-jpg
Added some more steel to top and bottom (like 'wrapping the ends'). Just to be sure it was over-done.:rolleyes:
577398d1541307185-cut-dump-trailer-coupler-weld-adj_coupler48-jpg
577399d1541307185-cut-dump-trailer-coupler-weld-adj_coupler50-jpg
All done! OK there it is.
/ Cut dump trailer coupler, weld on adjustable height coupler (w/pics) #2
Looks good, looks like you MIG'ed it between squalls and before the wind?
Now you'll be able to use a pintle if you wish.
/ Cut dump trailer coupler, weld on adjustable height coupler (w/pics) #3
Hey Sodo, looks nice! Long time no hear... how is your shop? All ready for winter?
/ Cut dump trailer coupler, weld on adjustable height coupler (w/pics) #5
What grade are those bolts? Did they come with the coupler?
/ Cut dump trailer coupler, weld on adjustable height coupler (w/pics) #6
Nice, Sodo! How long for the cut with that metal cutting skil saw?
I did it the night before last. A little wind but I turned up the gas to 30CFH plus I'd wait for calm before pulling the trigger. Someone can use a pintle hitch if I sell it but it's still a 10,000lb GVWR trailer (6x10). If you have a pintle hitch prob wouldn't look at 10k trailer. I think of its resale value but not selling for awhile. This thing has really been performing for me, it hauls 2.5yds maybe 3 yds.
Yeah shops all done insiode (just one wide bay of a 3-car). Now I wanna tear it down and make it bigger (8 ft high doors).
Thx dsn48, I painted if for you!;)
5/8" Grade 5 - came with the $58 kit.
Maybe 3x as long as if it was wood.
/ Cut dump trailer coupler, weld on adjustable height coupler (w/pics) #8
I have a Porter Cable metal saw that looks just like the one in Pic 2, they do a great job at making nice clean cuts where you can use them.
/ Cut dump trailer coupler, weld on adjustable height coupler (w/pics) #9
That hitch looks darn nice but I am still fretting about your excavator thumb that needs to be Kubota Orange II. Or Rustoleum Lobster Red.
.....i do have 3 cans of Lobster Red.....
But I'd have to prep that thumb. Not sure I can get myself to do that unless it was time to sell.
It's not bare. The guy painted it brown/gold.
/ Cut dump trailer coupler, weld on adjustable height coupler (w/pics) #11
I have seen many broken bolts and wollowed out holes on thst style of coupler. That was before we started adding shim washers and tightening them down against the coupler real good.
Nyone, when I assembled it and saw the slop it bothered me too. Loose becomes looser. Welding on the vertical bend likely pulled on it thus expanded it further.
Your post is a good one. In hindsight I would bolt it all together tight before welding on that bend.
A 3/4 washer dropped in there (.093?) and was just about right. The bolts squeezed it all tight so there is no movement and can be no wear.
Butler MFG Water Tanker (A61306)
Butler MFG Water...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 KOMATSU D65EX-18 CRAWLER DOZER (A60429)
2016 KOMATSU...
John Deere 5090GN (A60462)
John Deere 5090GN...
2010 CATERPILLAR 924H WHEEL LOADER (A60429)
2010 CATERPILLAR...
PALLET OF (20) BOXES OF CARPET SQUARES (A60432)
PALLET OF (20)...
