Starting our new life
   / Starting our new life #542
Interesting. Never heard of it. Also never seen it in the big box stores here in MN (Menards, Home Depot, Lowes).
It sounds like it would be more work that regular sheetrock because you have to spread mud (plaster) over the entire surface. I'd think that would lead to more visible tool marks and a need to sand the entire thing. The article doesn't make it sound like that though. Also seems difficult to have to do that full-surface plastering over the ceiling. But I guess it must work differently than I envision it working or else they wouldn't say it is 'much easier' than sheetrock.
Rob
   / Starting our new life #543
What is 'wallboard'? I've always heard that term used interchangeably with sheetrock/drywall.
Rob
The house that I grew up in, back in the 1940s, had "wallboard". Some type of fiber. No taped joints. The 4x8 sheets had a beveled edge that was part of the vertical stripe design.
   / Starting our new life #544
Rob
Yeah, I was hoping to understand how exactly the plaster is applied on blueboard so it is less work? :confused3:
   / Starting our new life #546
Seems like a thin coat of plaster would also lend itself more to chipping around nail holes or damage than would drywall. I'm not seeing the benefit either.
   / Starting our new life #547
I'm going to sound a bit cynical but here goes,
some people prefer the swirled textured look on walls and ceilings, myself I prefer the smooth flat ceilings and wall,
I also use ceiling lighting fixtures which will show any and all imperfections on a ceiling.
I belief the rise in textured coatings is due for the desire of the sheet rockers for speed,
NOT for the finished product to get a good true flat surface without seams and screw dimples showing up takes more time and skill then troweling on texture or spraying on popcorn.
This is just my opinion and preference.
   / Starting our new life #548
Agree. I remember textured ceilings was big in the 70s, especially tract homes. It cuts labor costs.
I think techniques and ways things are built go by regions. My wife and I wanted the finish we have on the walls and ceilings. The builder and tapers ask us how/what finish we wanted. The garage does have smooth walls with textured ceiling.
The finish wood work & tongue and groove should be done by tomorrow. I'll post some pictures when it's done.
   / Starting our new life #550
I agree Lynn. It's your choice. Finish it like you want. Doesn't matter if your choices reduces the required talent of your crew.
P.S. standing up my house walls today. If you look real close you can see me in the distance behind you. ;)
2015 Ford Transit 250 Cargo Van (A50323)
2015 Ford Transit...
2003 Lincoln LS Sedan (A50324)
2003 Lincoln LS...
KJ 33'x25' Double Garage Steel Barn Shed (A50121)
KJ 33'x25' Double...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
2017 Ford F-250 Enclosed Knapheide KUV Service Truck (A50323)
2017 Ford F-250...
CATERPILLAR VC60DSA SHOP FORKLIFT (A52472)
CATERPILLAR...
