DIY Digging trenches for Geothermal
   / DIY Digging trenches for Geothermal #51
I imported a Runshine 850 mini baler from Alibaba and a rotary rake also.There are a couple of US sites selling them for $7000, I paid $1800 plus import fees. I bought my property to keep busy, it would never pencil out. I would borrow a backhoe for your ground loops.Clay is good ,dry is going to need more loop length. I used 800' loops also. Like LD1 said the problem is watching out for rocks when backfilling.
I'm really interested in the baler and rake but don't want to hijack the thread. Can you start a new thread in either Haying or Chinese Tractors describing them?
Thanks.
Feel free to hijack the baler and rake on a subcompact is very interesting.
   / DIY Digging trenches for Geothermal #53
Geothermal fed tax credit is 30% and our state SC is 25% that is 55% off the cost so at least this year it can compete with a heat pump install.
About 5 years ago I did a DIY solar install 12.5 KW covers our home and driving our Chevy Volt 19K electric miles a year.
In the last 5 years we have driven 90K electric miles on solar power.
@Hickorypond that hay baler is very cool.
I am going to put in 2400 pipe for a 3 ton system that works out to 800' a ton.
I remain convinced (and yet to hear an argument otherwise) that the HVAC contractors are the ONLY ones who get any benefit at all from the 30% fed credit.
In my case, I was in a house with baseboard only heat, no forced air. So I needed all new just as a new built house would need.
Comparing a 4-ton conventional air to air unit to a 4-ton geo unit. With the air to air being a turnkey install....and the geo unit with me doing all the loop and exterior work and giving the contractors the lines through the wall to connect to.
I was utterly dumbfounded when the quotes for conventional were all in the $12k range and all the geo quotes in the $18k range.
Lets break it down to basics....
Ductwork is a big expense...but there is NO difference in material cost or labor cost. The ductwork dont care what type of furnace its hooked to.
Im buying ground loops and doing excavation so that is irrelevant.
Cost of the furnace package itself....surprisingly similar. $5k-$6k for a 2-stage geo unit...add another $800 or so for the pump center. Same 4-ton 2-stage air to air....pretty much same costs. But more labor to install actually, because you have an indoor and outdoor unit to set, have to supply power to both....and have to have a license to do the refrigeration work (not required on geo).
So Im scratching my head as to how in the world the Geo cost $6000 more :EEK:
I questioned the HVAC guys that gave quotes....ALL THREE had the EXACT SAME response.
"well it isnt really $6k more because you get a 30% credit...so its only a few hundred more."
Makes sense right. Who would spend $12k on a conventional system when $12.6k gets you geo right:thumbsup:
Yea....you aint fooling me. Did my own install, hired ductwork done only, was under $10k out of pocket. THEN I got to collect my 30%. And that even included a $1000 buffer tank for the desuperheater.
So to summarize.....I think the ONLY thing pushing the geo so astronomically expensive is because of the shyster contractors that do so, just because they can. Since I did the excavation and loops myself.....geo SHOULD have been cheaper AFTER the 30% by a good ways. But that makes no sense right....
When the tax credits and rebates go away, I look for geo cost to consumer to stay about the same. But it will put a BIG damper on the profit margins for the contractors.
I 100% agree with you and just told someone exactly what you said over thanksgiving.
When I did solar it was the exact same story, I got a quote for 4.6 KW system and I did a DIY install for 12.5 kw system cheaper.
Then I got the tax credit on top of that 30% fed and 25% state tax credit. It paid for itself 4 1/2 years.
The quote for GEO was 33K. The system i am buying and everything to install it is 9.5K that is before the tax credit. I will need to add digging equipment rental and i will sub out connecting it to the my duct work. The old system removal and the duct work I was quoted $600.
   / DIY Digging trenches for Geothermal #55
My LP Forced Air furnace cost me $700 brand new in the box. I did all the ductwork myself while doing the other renovations like drywall over block, new windows, etc. I wasn't doing central A/C so no outside work, copper coils, duct insulation, etc.
LP costs me less than $300 year and that includes cook stove/oven. Power for the fan/blower is my only other cost at maybe $10-15/mo over my normal usage.
I like the idea of GEO not needing LP, but I don't see even close to ROI in my lifetime. Same with solar, but the big difference there is when the lines go down for a week due to a storm.
   / DIY Digging trenches for Geothermal #56
No way to heat a house, and cook on $300 of LP here unless you live in a 500 sqft home with r-30 in the walls, and eat cereal year round
   / DIY Digging trenches for Geothermal #57
Yeah me neither. Not sure where he's located. I asked one time and got "why, you want to come and visit?" :)
   / DIY Digging trenches for Geothermal #58
We wanted geothermal when we built back in '93, but did not have budget. We heated with wood pellets (3 tons or so per year, at ~$110/ton) until we switched to propane for heating. We also plumbed for and added a 6 burner cooktop, so we heat and cook with propane, about 400 gallons per year, price varies of course.
   / DIY Digging trenches for Geothermal #59
^^ Yeah, I probably should have said 300 gallons, but since I get about 400 every 18 months, it averages out to somewhere around $300/year over the last 5 years. This time it was $1.699/g, but I've had it closer to a dollar not too long ago.
   / DIY Digging trenches for Geothermal #60
I'll take a picture of the rake & baler tomorrow, may start a new thread under Massey. Don't want to upset the real hay guys.
I work at a large HVAC R&D facility, I bought a Miami Heat Pump for 1/3 of their unit price and mine is built better. Dealer mark-up on unit is 2x minimum. And every time the government subsidizes the price goes up that amount. I paid $6000 for everything, including 2 stage unit,desuperheater,pumps ,pipe,buffer tank and a new water heater plus got 30% tax credit and $1200 from electric utility so $3000,same set up is $30,000 in my area. I did manual J myself so I know calculations are right.
2005 IC Corporation PB105 School Bus (A55852)
2005 IC...
Honda EM3800SX Portable Gasoline Generator (A55851)
Honda EM3800SX...
2014 Ford F-250 4x4 Ext. Cab Pickup Truck (A55852)
2014 Ford F-250...
2022 John Deere 1025R (A53317)
2022 John Deere...
Margaritaville Miniature Decorative Truck (A55853)
Margaritaville...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A55852)
2016 Autocar...
