Ether
   / Ether #41
I never have that kind of trouble. But, then I keep everything in good working order.
If you engine is wet, and won't crank, you have a lot of bigger problems than getting air to dry it.
So your point ignition tractor will sit out in a rain or snow storm and still crank? What did you treat the ignition system with to get that dependability?
   / Ether #42
So everybody with a "point ignition tractor" has to spray WD-40 all over the engine to start it, after a rain or snow storm?
I have owned, and operated many point ignition vehicles, including a MF35, and I have never had to do that.
If I did, I'd convert it to electronic ignition, or make some other changes to it, so it is dependable.
   / Ether #43
You're missing the point (no pun intended) that WD40 is a useful product.
   / Ether #46
Yes, so is duct tape, if that's the limit of your abilities.
If you think that having WD 40 and or duct tape handy is being an inferior mechanic...it is YOUR abilities and intellect that are limited...
   / Ether #50
I have read about holding a rag in front of the air intake on a diesel,, soaked in gasoline,,
the gasoline fumes aid in starting a cold diesel,
This seems safer than ether,, if it works,,
Does anyone have first hand knowledge of gasoline fumes aiding in starting a diesel??
A friend tried the gasoline soaked rag trick on a clapped out backhoe. It didn't work that time. It looked like a good way to get burned alive to me.
I 've used starting fluid for years on my lawnmower because I'm too lazy to rebuild the carb. The mower still runs.
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2014 Volkswagen Passat Sedan (A53117)
2014 Volkswagen...
Hydrema 912HM Haul Truck (A52384)
Hydrema 912HM Haul...
2004 IH 5600l Snow Plow Truck (A52384)
2004 IH 5600l Snow...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
Kubota RTV-X1100C 4x4 Utility Cart (A51691)
Kubota RTV-X1100C...
