Ethanol vs non ethanol gas
   / Ethanol vs non ethanol gas #11
That manual I linked to calls for 89 octane. No point in using 91.
   / Ethanol vs non ethanol gas #12
2008 was when they started adding ethanol up here, and it was all that you can find. That saw's long gone anyhow, more and more stations are selling ethanol free in their premium pumps and that's all that I will run in my ATV, chainsaw, outboard, and various other small engines. My 545 has never had ethanol.
   / Ethanol vs non ethanol gas #14
Used ethanol in my 1982 Stihl, which is the oldest engine i have. Doesn't get near as much use as it did. To start it, choke, pull once, pop the trigger, pull and it starts. No mushy fuel line. Only thing is, the ethanol makes my chain dull sooner then it used to.
   / Ethanol vs non ethanol gas #15
That's not surprising. It also causes male pattern baldness; I didn't have this bare spot until I started using E-10 back in 2008.
   / Ethanol vs non ethanol gas #16
Hmmm.... I never made the connection, but now that you mention it.... hmmm.... :scratchchin:
   / Ethanol vs non ethanol gas #17
I don't use any ethanol blend in any air-cooled engine primarily because of "phase separation". I've experienced the effects and it isn't pretty.
   / Ethanol vs non ethanol gas #18
For at least the past 10 years I've used Lucas ethanol fuel treatment on all my 4 and 2 stroke engines and they have performed just fine. I do buy non ethanol fuel when it's convenient.
   / Ethanol vs non ethanol gas #19
We don't have ethanol free 89 around here. At least I've never seen it. Only 91.
Odd. I can't find anything around here other than 87 octane non ethanol. Is there a fuel treatment that raises octane level?
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A52748)
NEW 2025 Load...
2017 E-Z Beever M12R Towable Brush Chipper (A51691)
2017 E-Z Beever...
1998 FORD CRANE (A52472)
1998 FORD CRANE...
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
2023 PETERBILT 579 TANDEM AXLE SLEEPER (A52576)
2023 PETERBILT 579...
2007 IC Corporation PB105 Passenger Bus (A51692)
2007 IC...
