Easiest way to change hitch ball sizes
   / Easiest way to change hitch ball sizes #1
dgeesaman
Harrisburg, PA
New Holland TC45DA
I have a TC45 w 2-5/16 hitch on my drawbar.
I want to also be able to pull my splitter which has a smaller ball. I need an inexpensive way to switch hitch balls back and forth that preferably does not involve busting the hitch ball nut with an impact every time.
Thanks,
David
   / Easiest way to change hitch ball sizes #2
Thanks,
David
I did something like this.
Only to to used around the woods or yard.. NOT HIGHWAY...
I'm going to get scolded how unsafe it is but works for me..
   / Easiest way to change hitch ball sizes #5
I'd figure out how to pin a triple ball hitch to your drawbar. Maybe get one of theses and add a hole on the two axis to match your drawbar holes.
   / Easiest way to change hitch ball sizes #6
I had a similar type of hitch I welded a short receiver tube to the bar stock to enable using different hitches.
   / Easiest way to change hitch ball sizes #7
Get a hitch receiver frame for your 3-point hitch. It is loads easier to use than dealing with the fixed drawbar and has a standard receiver tube that you can use to swap out draw bars or rotate a 3-ball setup. Once you get used to hitching up this way (back up to trailer and lift the 3-pt from your seat) you’ll never go back to the old way.
   / Easiest way to change hitch ball sizes #8
You're not supposed to pull trailers from the 3pt hitch. You're supposed to pull trailers from the drawbar. Yeah, I know most people don't and never have a problem. Just sayin.
   / Easiest way to change hitch ball sizes #9
^^ I had to go that route. The trailer ball mount was far too low and there was no way to raise it or add a receiver hitch without getting in the way of the PTO and other things. I tried several different ways and nothing worked.
I don't try to pull big trailers though, just the splitter and a small utility trailer.
   / Easiest way to change hitch ball sizes #10
The OP is interested in pulling a woodsplitter,, not a Fruehauf 53 foot reefer full of ribeyes ,,,
Heck, he could almost hold the hitch in his hands to move the splitter,, the 3 point should be fine,,,
2012 BRUMLEY MANUFACTURING DATA VAN TRAILER (A55745)
2012 BRUMLEY...
2005 FONTAINE 48 FOOT FLATBED (A53843)
2005 FONTAINE 48...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2024 Bintelli ActivEV Pulse Electric Cart (A55853)
2024 Bintelli...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A54607)
PEMBERTON...
DYNAPAC CA30D SMOOTH DRUM ROLLER (A52707)
DYNAPAC CA30D...
