Buying Advice New Tractor Help - Kubota B2601 or Deere 3025e
   / New Tractor Help - Kubota B2601 or Deere 3025e #71
I didn't have any problem at all getting mine off once I figured out the steps. Found out my gauge wheels turn 90 degrees at a height that allows me to simply roll it out sideways.
Exactly right!!!
   / New Tractor Help - Kubota B2601 or Deere 3025e #72
Huge learning curve on a zero turn. Not as easy as it looks.
Took me a few mowings to get it down pat, after 3 years it's not an issue.
At the farm there's a mile of fence to mow, both sides...a MMM is easier, a rear mount sucks. rips / bends the posts (all steel ones).
Saw a DR 'weed whacker' that could be tractor mounted...thinking that over
   / New Tractor Help - Kubota B2601 or Deere 3025e #73
I moved from a Kubota 2620 to a JD 2038R a year ago. I can't tell you a single thing that I think was better on the Kubota. The reason I started looking for a new tractor in the first place was because my Kubota dealers service was just awful. Whatever you decide to go with, make sure the dealer is top notch.
   / New Tractor Help - Kubota B2601 or Deere 3025e #74
Stop hitting the posts with it and you won’t have that problem.
Sorry but the reality of it is that every person I ever met who had a problem with busting things up with a rear mount just simply could not drive anything very well at all. I use a rear finish mower and get a better cut, get closer to things and have less to trim with the weed eater than any mid mount I ever owned or used. This all without tearing anything up ever!
   / New Tractor Help - Kubota B2601 or Deere 3025e #75
Really? I've been trying to figure out how to do that, both mount and power.
I suppose it has a 'DR price' though doesn't it?
   / New Tractor Help - Kubota B2601 or Deere 3025e #76
i've not found a way to mow a mile of fence and get under the fence and not hit post every so often. a rear mower is just that much harder to watch. I do not want to weedwhack it and the lady of the house doesn't want chemicals
   / New Tractor Help - Kubota B2601 or Deere 3025e #77
   / New Tractor Help - Kubota B2601 or Deere 3025e #78
on sale for $1100.
I hate string trimmers..no idea if this 'string' lasts longer or what it is made of.
3-Point Hitch Trimmer Mower: String Trimmer and Fence Mower | DR Power Equipment
The first iteration of the product had many issues, but DR did a redesign a couple years ago that seemed like it would solve the problems. I haven't read all the reviews since then but a quick glance shows an improvement from all the previous 1-2 star reviews.
I contemplated getting one to mow the ditches along my driveway, since sickle mowers were out of sight on price. Then I thought about building a 3-pt mount to position an old lawn mower off to the side. In the meantime the ditches grew in a bit and we like the look better. Problem solved for $0.
   / New Tractor Help - Kubota B2601 or Deere 3025e #79
The treadle is odd for the first hour, then you have absolutely no conscious knowledge that your foot is even on it and doing it's thing. I sure wouldn't let that have any weight on deciding. If your brain is unable to convert that treadle action to unconscious muscle memory in a very short time of use, you likely need to wear a helmet and carry a droll towel....
Actually the treadle was odd for about the first 8 hours for me. Now I kinda like it.
PENDING SELLER CONFIRMATIONS (A51222)
PENDING SELLER...
2020 VOLVO VNL760 SLEEPER (A51222)
2020 VOLVO VNL760...
2013 Ford F-150 4x4 Ext. Cab Pickup Truck (A48081)
2013 Ford F-150...
2000 MACK RD688 TRI AXLE DUMP  TRUCK (A51222)
2000 MACK RD688...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
AGT Agrotk 680 Drop Hammer Attachment (A47384)
AGT Agrotk 680...
