Parbuckle those logs onto the truck
   / Parbuckle those logs onto the truck #11
Ten or so years back, one of the channels I got on cable showed a draft horse logging operation. The horses pulled the logs up beside of a truck with forks that flipped down and loaded the logs much the same way as many bandsaw mills do these days. I think the power to the forks was provided by a cable which, in turn, was lowered by the truck's engine. I never saw another loader like it.
   / Parbuckle those logs onto the truck #12
If it's the same show I saw, that type of log loader was powered by cables that are wound by a differential that is located under the truck and powered by a PTO on the tranny. As I recall, when the kid pulls the lever, it locks the brake on one end of the differential, causing all the power to go to the opposite side, which has the winch drum on it. The winch winds rapidly and it basically throws the log up over the side rails onto the bed. The kid lets go of the lever, the brake releases, the winch drum loses power, and the lift arms fall to the ground again. Very effective and kinda dangerous!
That sounds as bad as this one.
Bruce
   / Parbuckle those logs onto the truck #16
Here's some pictures of the mechanism I found on the google.
86DF7D4B-7D8F-4E20-A4BD-65B430B56AA4.jpeg. CF4C65EE-8FFF-4490-BE41-989A450910F7.jpeg
   / Parbuckle those logs onto the truck #18
I had thought about building one of these side loaders for my trailer. It would make quick work of loading up a couple dozen telephone pole sized logs and bringing them home to cut, VS cutting them on location and having to toss all the rounds onto the trailer. Still thinking about it. Or a rear arch on the trailer. I think that would be more practical for my needs.
   / Parbuckle those logs onto the truck #19
Man, he sure lowered the grade on that log he cut!
SR
FRONTIER WR3212 LOT NUMBER 57 (A53084)
FRONTIER WR3212...
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
2025 New/Unused Wolverine Pallet Fork Frame (A51573)
2025 New/Unused...
1998 Ford F800 2,000 Gallon Water Truck (A52377)
1998 Ford F800...
New/Unused 78in Quick Attach Rock Bucket (A51573)
New/Unused 78in...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
