Propane Whole House Generators, Warning.
   / Propane Whole House Generators, Warning. #111
I haven't read all the responses but have a few comments on the video.
1. The guy obviously did not inform himself before setting up his system. I would never consider using a 250 gallon tank for a 17Kw genset. We have a 500 for our 20Kw and while we have not yet had an issue, I've been thinking maybe I should have put in a 1000. Main reason I didn't initially is that they charge you extra if you don't use the "expected" amount per year based on tank size.
2. His lack of understanding of the "usable capacity" of a propane tank is further revelation of his lack of research. The reason the last 20% is (mostly) unusable is because of evaporation. As you no doubt know, propane is stored as a liquid but used as a gas. That only happens as a result of evap, and evap is limited by the surface area. With a horizontal cylinder, when very "full" (80%) or low (20%) there is no longer enough surface area to evap sufficient volume of gaseous propane to provide combustion. Obviously those are starting points - if you have a 1000 gallon tank running a 6k genset you will be able to go considerably below the 20% level. There are charts that show evap rates.
3. The biggest advantage of propane (to me) that he didn't even mention, is that it doesn't go bad, and is easy to store in relatively large volumes. He talks about the fact you can't go down to the local gas station and buy a 5 gallon bucket of propane, but if there are widespread power outages the gas station will not be able to dispense anything. There's no way I'm going to store enough gas or diesel to last for a week of constant running and "hope" I need it. The occasion is going to be rare, and that fuel is likely going to sit for years. No thanks.
4. If you are in a potentially long-term power outage, DON'T run your genset 24/7! There's (likely) nothing you need that has to be on ALL THE TIME! Unless you have a medically life-threatening condition that requires power, in which case I suggest you have a few 1000 gallon tanks and a small genset that powers just the essentials...
Somewhat related to the conversation, our most recent genset purchase was a Cummins. Same model as in the video but 20Kw. One of the primary reasons for choosing it over the Generac and Kohler were its lower burn rate...
   / Propane Whole House Generators, Warning. #112
Last time the power was out here for a full day, a gas station 4 miles from here had a generator running and was selling gas.
I bet that wasn't the only one either! They can sell a LOT of gas when the power is out and they know it!
BTW, I've NEVER had ANY diesel go bad!
SR
   / Propane Whole House Generators, Warning. #113
Funny thing is the number of people i give bids to for whole house systems, there are quite a few that figure out price is too high for something that they may or may not need. Amazing to see how many top end snow machines and razors i see in their garages....that never get used much either. Its all how a person feels he needs when the grid is down. I would say 90 percent of my clients have a deep water well so to them it is worth it. If i was on city gas, water and power i wouldnt install one either.
   / Propane Whole House Generators, Warning. #114
I remember the ice and milk being delivered by horse and wagon in the fifties and didn't live in the sticks. Times have changed.
We have one of these ice chests in similar condition as this google picture out in my shop that I coincidently told my wife last weekend we need to bring into the house.
   / Propane Whole House Generators, Warning. #115
SR
And they have a gas generator and a BIG fuel tank?
   / Propane Whole House Generators, Warning. #116
Yep I have lived on well water the majority of my life. When a storm is predicted I fill the tub with water. Even now that I have a generator that can run the well I do it out of habit.
We have horses so I need on the order of 70 gallons of water per day (more than double that in the heat of summer) so I have to be able to run the well.
Thankfully I live far far away from hurricane land. So even after a major storm finding gasoline is easy for me.
From a cost vs morale perspective I will run the genny enough to keep the house warm, not just the pipes from freezing. During that time the fridge/freezer can be powered too so no worries there.
Main issue we would have in a long outage is the stove is electric and we do not have that tied into the generator. So we might end up having to get a hot plate or something to cook on. In the summer I would just grill for every meal.
Knock on wood at our current home we have had 1 outage in 3 years that lasted more than an hour.
You have I&M? We have I&M and I have to say they are pretty darn reliable. If we ever move to our property, it'll be NIPSCO. I've had no experience with them other than everyone out there telling me how expensive they are.
We also have a wood stove, so heat isn't an issue with us, but water and flushing the toilet are high on our list of creature comforts. :laughing:
   / Propane Whole House Generators, Warning. #117
Just to be clear, the guy never said he ran it 24/7. It's a 24/7 standby generator. The longest he ran it was 8 hours at a time. That's why he only had 51 hours on it after almost a week of running it about 8 hours a day and using his RV diesel generator the rest of the time. And after 51 hours, he only had about 31 hours of propane left in his tank at minimal load.
   / Propane Whole House Generators, Warning. #118
We are fortunate in that one of our cattle properties has an artesian well that feeds the water tanks with about 5 PSI. The other has an irrigation ditch on a hillside that is fed from a siphon off of a local river serving up about 15 psi. No electricity required on either.
   / Propane Whole House Generators, Warning. #119
Cost about $1000 US at Lowe痴 right? And is yours the fuel injected model?
No the XT8000E is no longer carried at Lowes. It has worked very well for me, YMMV.
   / Propane Whole House Generators, Warning. #120
Yes I&M here too. We are on a circuit w only 6 houses. It has been very reliable.
2017 Mitsubishi Mirage G4 Sedan (A53424)
2017 Mitsubishi...
10ft X 5ft Livestock Corral Panel (A55758)
10ft X 5ft...
2021 Hyundai Elantra SEL Sedan (A55758)
2021 Hyundai...
2019 Ford F-550 4x4 Ext. Cab Chipper Truck (A51692)
2019 Ford F-550...
2003 Pierce Spartan Pumper Fire Truck (A55852)
2003 Pierce...
White Metal Roof Panels (A55758)
White Metal Roof...
