I Seee Tractor Supply Has Travellers Permetran/ 821 Equivalent On Sale $40
   / I Seee Tractor Supply Has Travellers Permetran/ 821 Equivalent On Sale $40 #11
When I bought my tractor the dealership told me that as long as I kept the tractor full with oil that met spec the warranty was good. They acknowledged that AGCO oil was way overpriced, I still get my filters there and they are a bit spendy. My tractor requires 10 gallons of oil, so a $30 difference in 5 gallons does add up.
   / I Seee Tractor Supply Has Travellers Permetran/ 821 Equivalent On Sale $40 #12
If it meets the Specs., it's good enough for the equipment that requires those Specs.
If a machine needed semi or full synthetic oil, the manufacturers of their machines would specify that in the Owner's Manuals and ship their tractors with the same. Regardless, I always change my oil and filters at the intervals that equipment manufacturers specify.
That's the way I see it. But like always, "To each, their own."
Meets the specs, still doesn't mean it's as good.
No, not everyone needs synthetic oil. But, some do need it.
If a piece of equipment was made before synthetic was readily available, or a manufacturer has not chose to switch yet, it doesn't mean some can't benefit from doing so. You shouldn't wait for a telegram from them, it may not come.
BTW: Kubota is now selling a hydraulic oil that is 75% synthetic, and recommending it be used in their equipment.
   / I Seee Tractor Supply Has Travellers Permetran/ 821 Equivalent On Sale $40 #13
It also does not mean it is NOT as good either. It very well might be.
   / I Seee Tractor Supply Has Travellers Permetran/ 821 Equivalent On Sale $40 #14
Let me know. Because, I'm just going to pay a little more for a product I know is good, and not have to think about it. :thumbsup:
   / I Seee Tractor Supply Has Travellers Permetran/ 821 Equivalent On Sale $40 #15
50+ years using name brand or equivalent Spec. oil in various tractors, crawlers, and smaller machinery without a single oil related problem, engine and transmission, manual and hydrostatic. (Allis-Chalmers, I.H., Cub Cadet, John Deere, and Kubota) :)
Now you know! ;)
   / I Seee Tractor Supply Has Travellers Permetran/ 821 Equivalent On Sale $40 #16
50+ years using name brand or equivalent Spec. oil in various tractors, crawlers, and smaller machinery without a single oil related problem, engine and transmission, manual and hydrostatic. :)
Now you know! ;)
Yup......meeting manufacturers specifications is all that is necessary.
Anything else that costs more $ is wasteful overkill.
   / I Seee Tractor Supply Has Travellers Permetran/ 821 Equivalent On Sale $40 #17
Now you know! ;)
Anything else that costs more $ is wasteful $ overkill.
   / I Seee Tractor Supply Has Travellers Permetran/ 821 Equivalent On Sale $40 #18
Now you know! ;)
Some MF GC owners have complained about brake chatter, and hydro pump whine, when they used cheap fluid.
So, now you know. :thumbsup:
   / I Seee Tractor Supply Has Travellers Permetran/ 821 Equivalent On Sale $40 #19
When I drained the initial fill on my MF GC1720 it was discolored and obviously had the jabeezus beat out of it. I replaced it with some expensive oil. I don’t know if it will make a difference or not. Oldoak has had success using name brand oil and that’s a problem I have with TSC oil It may be just as good or even better than Mobil, Chevron and Shell but I don’t know that for a fact and do not want to experiment. Most of the stuff TSC is cheap, kind of like a Harbor Freight for farmers and ranchers so I personally do not consider their oil to be name brand. Just my view on this, could be wrong and not trying to convince anyone of anything.
   / I Seee Tractor Supply Has Travellers Permetran/ 821 Equivalent On Sale $40 #20
That tsc universal tractor fluid was beat up in my skidsteer thats much harder on fluid. Years of it. I trust it.
Quick Attach 80" Rock Screening Bucket (A50514)
Quick Attach 80"...
Case 830 Tractor (A50514)
Case 830 Tractor...
2011 Mazda 6 Sedan (A50324)
2011 Mazda 6 Sedan...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A52128)
Toyota 6FGU25...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2017 Buick Regal Sedan (A50324)
2017 Buick Regal...
