Rant time !!! Bureaucrats at it again .... New home build
   / Rant time !!! Bureaucrats at it again .... New home build #1
Navvet
NC
Mahindra 4025 Bobcat S185 John Deere X495 John Deere 6x4 Gator
A little background, My wife and I retired from the Navy. Me, early retirement at 17 years, her 20 years. Our plan was to get some land, semi rural, but close enough to family and bigger cities to be convenient. We ended up with 20 acres at the tail end of a 1.5 mile private gravel road (good excuse for a tractor). Lots of trees, wildlife, and privacy.
When we bought this place, our intention was to live in the single wide that was on the property for a few years until we found a house we would like to spend the rest of our retirement in. A few years into our plan I was diagnosed with cancer (Sadam's / Chemical Ali's revenge).
Now that the medical issues have settled out, we decided it's time to build the house.
We have been looking at one of the (upscale) modular home builders in the area and settled on a plan. I made the preliminary order for the house just before Christmas and today I went for the Planning and Zoning permit.
As Gomer used to say ... Surprise, Surprise, Surprise .....
Our county approved a new (2012) Watershed Stormwater Management regulations. I am a firm believer in managing construction activities and stormwater run-off. I know there can be significant repercussions to mis-management, but I do believe everything should be properly proportional.
The regulation covers any development / re-development / land disturbance after mid 2012 and limits land disturbance for residential zoned properties. Any residential property, 1 acre, 10 acres, 30 acres, (the size does not matter) is limited to 1/2 acre (21,780 sq ft) of CUMULATIVE land disturbance. This includes things like driveways, septic systems, digging in your yard, etc. If I wish to exceed the 1/2 acre I am required to hire an "approved storm water engineer" to provide an assessment and stormwater management plan as well as a $1,000 escrow deposited for the counties storm water review.
According to the planning folks, even a 2 car metal carport does not require a building permit but does require zoning permit.
I'm not sure how big my septic will end up being, but I built a 1000 sq ft garage 2 years ago and the house / deck will be in excess of 4500 sq ft ..... I'm starting to run out of space on my 20 acres.
End Rant ....
   / Rant time !!! Bureaucrats at it again .... New home build #2
I don't think that has to do with bureaucrats, but more likely came about from poorly planned developments that had too many houses on too little land to support proper septic, and groundwater/water well contamination starts.
We have similar things going on here. Back in the late 70's through the 90's they were slapping up housing developments left and right. Pretty densely packed. Now many of their septic systems are failing and their wells have human poop in them. There's no additional land to put in replacement septic fields. So now they're looking at forces municipal sewers and water.
Then they also found lots of silt runoff during construction, so now everyone has to put up silt skirts when building houses.
And many of the housing developments flooded after we had several 100 year rains in just two years, so now there's stricter drainage rules.
So take some comfort that it's not just your area.
   / Rant time !!! Bureaucrats at it again .... New home build #3
Moss Road Had the exact same thing happen in Anchorage. Large subdivisions, small lots - no public sewerage or public water systems within miles. WoW - the expense those folks had to foot to have the public utilities extended to serve their homes.
Development without adequate planning.
   / Rant time !!! Bureaucrats at it again .... New home build #4
The thing is as usual the government solves one problem by screwing over everyone. Certainly the issue Moss raises is important and needed solved. It does not need to be applied to a 20 acre parcel though.
Moss - the silt barrier is what I am seeing them put around houses that looks like a ring of sand bags?
   / Rant time !!! Bureaucrats at it again .... New home build #5
The same problems can occur on one or twenty acres, but twenty gives you cheaper corrections if original installation is wrong
I agree with the necessary planning, but, limiting some one with 20 acres to the same 21,000 sqft of land disturbance as someone in a subdivision with 1 acre lots ??? That is a bit excessive. I have a garage, workshop, and a house. I want to put in a 1,000 sqft barn but the land disturbance total with the area of the septic (and it's planned repair area) included is pushing my properties limit.
According to them, I can't uproot a tree without a zoning permit and including the amount of land disturbed.
   / Rant time !!! Bureaucrats at it again .... New home build #7
The government has to make the law so it applies to everyone, then allow exceptions.
End Rant ....
You don't say how long you've been there, but refer to the law as "new (2012)". Was the law there when you bought?
I'm sure your familiar with the fact that water flows downhill, there have been many threads on here about people having problems with stormwater coming from neighbors at higher elevations.
In Virginia I've two houses in Alexandria (dense suburbs). On one both of my suburban neighbors pipe their sump pumps so they spew on my land, but they don't care. My yard fills up like a shallow swimming pool. But at least it drains in a few days. The other the house is on a narrow half acre about at the peak of a very gentle hill, and the soil is marine clay. A house flipper bought the half acre 60 yr old house and property adjacent down hill from mine. He put on a 24x30 addition, which required digging out a massive amount of dirt for the foundation. He dumped it all on the back part of his lot, raising it by several inches, putting the back half of my lot under about an inch of water after EVERY rain. And it wouldn't drain. So it was a swamp all one summer.
I took my backhoe, dug a ditch that stopped at the property line. Heavy rain occured and flooded the far ends of our lots and cut a new channel on his lot.
   / Rant time !!! Bureaucrats at it again .... New home build #8
Just split the property into 2 lots and then you get 2 exemptions. Here we had to split property for tax reasons. Built house on the farm and taxes went through the roof because of the ''structures'' on the property. Split the house from the barn and now it is considered an ''unoccupied'' lot and our taxes went down on both. They are 65% of what they were together
I bought this place 21 years ago. I have talked to a couple of builders and what sticks in my craw is this was passed without any notifications. Just one day it was there.
Unfortunately, one of the new laws I do know about limits private roads. My road has 10 nice lots on it, 3 to 7 acres with my 20 at the end.
Now, if you put in a private road with 4 or more lots it is considered a subdivision. it must be paved, 40' wide with 10' shaped drainage on either side. There is also something about streetlights in the rules.
We are currently grandfathered on our little road so to split my property I would be required to bring my 1.5 mile road to subdivision specs.
   / Rant time !!! Bureaucrats at it again .... New home build #10
Similar situation for us with "resource protection areas" that are intended to minimize erosion and sedimentation affecting the Chesapeake Bay watershed. It's a major pain in the butt. It came about since previous generations abused the land for farming and real estate activities, clearing right to the waterline with little or no management of runoff and stormwater, so a lot of sediment ended up in the rivers and bays. Now people doing any new land development pay the price. I have learned to suck it up and be a good steward of the land, which sits on my conscience better anyhow. The cost and the regulations never feel right but I have learned how to work within the system. Sad thing is, I probably would be careful on my land anyhow, without the need for nanny treatment.
2017 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A60460)
2017 Ford F-550...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A55745)
2010 MAXEY WELDING...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
2008 Bobcat S250 Compact Wheel Loader Skid Steer (A59228)
2008 Bobcat S250...
