Buying a used trailer? Be prudent.
/ Buying a used trailer? Be prudent. #1
John White
Gold Member
Newark, Oh
Bob Cat Ct335
I have a 12K gvw 16' trailer and have been looking for a used one for about 5 years. I Wanted a 14k gvw and 16' with a 2' dove tail. Hard to find. I didn't want to pay more than what I could get out of my present trailer. It has served me well for 10 years and is a well built trailer. I found a 16+2 on Craig list in Pa. It didn't look too bad by the pictures. He said the tires were bad. So I made arrangements to go look at and pick it up between snow storms. (450 miles) I took the usual things you might need in picking up as trailer. Magnetic lights with plug already attached, screw drivers, wire cutters, tape, circuit tester, jack, spare tire, crescent wrench, pliers.. It was getting late in the evening when I got there, about 10 degrees, way out in the boonies.. It was a Load Trail. 2010. He said they bought it new and hadn't used it in two years because they got a shorter trailer for their bobcat. He said in Pa. you have to have them inspected every two years, including pulling the wheels checking the brakes and bearings.. I looked it over and I could see it needed tires (he told me that) I wasn't sure I could make it home on the ones on it. It needed new stake pickets welded back on it, probably a new paint job to make it look good. I jacked it up to check the bearings, they all made a little noise when turning them, rust from sitting so long. One seemed a little tight but not bad. I got the lights hooked on it. I was sort of disappointed in the condition. Has powder coated wheels and most paint is chipped off it and rusted. I felt bad after driving all that distance. and going back empty. I made him a offer of $1000 less than what he had it listed on Craig list. He took it. We had to drive several miles to get title notarized . By the time I got back to trailer it was after dark and getting colder. I hooked up and off I went. Stopped about 25 miles to check the lights, hitch wheels, tires. I noticed one wheel was pretty hot. It cooled down very fast because it was so cold. Drove another 25 miles and hot again. I finally found something to knock the grease cap off (it had ez lube) I got my grease gun out which I seldom use that one. Grease was so cold and dried out, couldn't get it to work. Drove another 25 miles, pulled into a rest area. Took the grease gun inside the rest room, took a tooth pick and picked out all the old grease and threw the old tube away. Put a new tube in it and finally got it to pump. Lubed the spindle real good. Drove another 25 miles and checked it again, still very hot. Drove another 25 miles and got a motel. All I could vision was the bearing locking onto the spindle and ruining the axel. Next morning I want on a ways till I came to another rest area. Got the cap back off and finally got the cotter pin out. The axle nut was so tight I couldn't loosen it with pliers. Crescent wrench wasn't large enough. All I had a was a hatched and a masons hammer. Finally beat the nut off. Put it back on and properly tightened it. Made it on with no trouble. All my trailers over the years when first getting them home is to remove all wheels, inspect brake, clean and repack bearings. This could have turned out to be a real disaster.(one wheel is too lose) So much for Pa inspection. (if he ever had it done) So if you ever get a used trailer or new even, take a jack and jack it up and check wheel bearings.
/ Buying a used trailer? Be prudent. #2
When I stopped working on semi trailers in the 90's (started my own business unrelated) there were guys installing semi wheel bearings using an impact.
As the saying goes, "as tight as it will go and 3 more turns!"
You never know what you are getting, even brand new!
/ Buying a used trailer? Be prudent. #3
Your advice is worth remembering and your tenacity is worth commendation John. I could hardly keep from shivering while reading those rest area stops in that weather. One piece of advice you offer could easily be overlooked even by those who take pride in maintaining their equipment. No need to pull hubs on a new trailer,right? Wrong. I bought a new trailer and turned all 4 spindles and bearings blue before realizing they didn't have any grease. When I called manufacture,they confirmed greasing bearings was not part of their assembly process. Since trailers hold resale value so well,it's not uncommon to buy a trailer rather than renting to transport a load in an emergency. What does the manufacture expect,buyer to service trailer before driving off their lot?
/ Buying a used trailer? Be prudent. #4
450mi to save a few bucks on a used trailer you found after 5yrs looking....**** a gluten for punishment.
/ Buying a used trailer? Be prudent. #5
People want high prices for junk trailers I always end up buying new. Even so have to check wheel bearings spring hangers lug nuts.
/ Buying a used trailer? Be prudent. #6
We bought a new 20' trailer put a Land Rover on it and a pop up trailer. (Rover did not like going over 55 and would not go over 45 with the trailer.)
Drove it 150 miles and stopped and bought a Weight Distribution hitch and anti-sway bar.
Pulled it 1500 miles through the mountains in Colorado on a elk hunting trip. Coming back we went trough 2 tires and gave up on trying to pull it while loaded. We unloaded the trailer and drove separate vehicles.
We took the trailer back to the manufacture and they found the axles were not tightened down.
/ Buying a used trailer? Be prudent. #7
That was my experience a couple years ago when I bought a tilt bed. Tilt beds are hard to find used in my area anyway, but trailers in general have folks asking very close to new prices for old stuff.
Like the OP, I drove to PA. But it was because I got a deal on a new one from a dealer that made it worth the 3 hour trip. Add to that the fact that I didn't have to pay my state (NY) sales tax. I would have had to pay it at registration time but I opted for a Maine trailer registration. Over $75 per year in NY. $100 for 5 years for a Maine plate.
/ Buying a used trailer? Be prudent. #8
Im from NY too. Ny has not got any of my trailer registration money, ever. I have about 4 trailers at the moment and only 2 plates. I dont see the point in having more than 2 plates as most regi say black utility trailer. Its actualy not a NYS law to register your trailer in the state you live in.
/ Buying a used trailer? Be prudent. #9
I have 4 trailers. 3 have Maine plates. I only kept NY plates on a business trailer that has a huge company logo on it. And I'm even wondering why I bothered to do that. Maybe this spring I'll put a Maine plate on it and be done for 5 years.
Some have said it's not legal, some have said it's a gray area, some have said it's OK. I can only say that I've never been pulled over for it in the many years I've done it. And I've done it at least long enough for a couple of the 5 year Maine plates to be renewed. My motorcycle hauler has been back & forth to Florida several times. If I ever do get stopped and ticketed, I'll still be a lot of money ahead.
/ Buying a used trailer? Be prudent. #10
I have Maine plates on my two trailers (in MA.)
A local hauling company has 5 large dump trailers...all are registered in Maine, though the tractors pulling them are registered in MA.
/ Buying a used trailer? Be prudent. #11
Check out the trailer plates on tractor trailers next time you're out on an interstate. You'll see a lot of Maine plates with tractors that have all different kind of state plates.
/ Buying a used trailer? Be prudent. #12
Look up the NYS trailer registration laws. They hust state it needs to be registered. But as for vehicles it says must be registered in the state the owner lives.
I know a nys truck inspector. Thats not a ticket they wright and you never see semi trailers registered in NY.
/ Buying a used trailer? Be prudent. #13
I don't understand all that trouble. Here in VA, you can get a Permanent (non-expiring) trailer plate for $75 +$10 one-time title fee. None of this 5 year stuff.
/ Buying a used trailer? Be prudent. #14
Do you need to live in the state? Ny is a yearly fee and yearly inspection. I have 3 vehicles and 4 trailers..thats alot of tegistraion fees and trips to the inspection station.
/ Buying a used trailer? Be prudent. #15
You can home build a trailer,use it on public roads for farm use,keep it below 4k Lbs without safty inspection, titling or registeration in Texas. Sound's all good until you actually do it and get ticketed by cops that don't know it's legal. Make's it cheaper to go through the process than pay tickets or spending time going to court.
Meanwhile,trucks out of Mexico legally operate without registeration,proof of insurance,safty inspection,meeting DOT requirments such as worn tires,leaky brakes and burned out lights.
/ Buying a used trailer? Be prudent. #16
True....but you must LIVE in VA. to do that.
You DO NOT need to have a Maine residence to have a Maine trailer plate.
The $20 per year is a smoking deal compared to most other states.
/ Buying a used trailer? Be prudent. #17
I'm a NY resident that does Maine registrations because they're $100 for 5 years. New York is yearly for $75 plus, depending on weight. So that's why the trouble. We don't have the option that VA does.
/ Buying a used trailer? Be prudent. #18
I keep a copy of the section of Texas Motor Vehicle code with my Tow Vehicle just in case.
I am curious . In the states that you make you have your trailer inspected as in Pa and others. What do they check for. Do they pull all the drums and check your brakes as the fellow I bought this trailer off of said they do? I think it is a money making deal.
/ Buying a used trailer? Be prudent. #20
They check lights and possibly pull one drum in NY.
