Kubota Gas vs Kubota Diesel engine option
/ Kubota Gas vs Kubota Diesel engine option #122
Would it be possible build a gas motor that doesn稚 spark and instead runs like a diesel? Maybe the fact it痴 never been done or at least mass produced would suggest the answer is no, but why not?
Gas is measure in Octane and Diesel is Cetane. I Racing car engine has about 9-11 pounds of compression and the help from a spark plug. Diesels run, what, 60:1 compression/ I think you would need a lot more then diesel compression to compress gas enough to explode on its own.
/ Kubota Gas vs Kubota Diesel engine option #123
No problem to ignite gas by compression, the problem is to do it in a controlled way.
What did you decide?
Kubota 3 cylinder engines .. BOTH Gas and Diesel are great.
I bought the diesel model. Very pleased -- it does a good job.
/ Kubota Gas vs Kubota Diesel engine option #126
Gas is measure[d] in Octane and Diesel i[n] Cetane. I Racing car engine has about 9-11 pounds of compression and the help from a spark plug. Diesels run, what, 60:1 compression/ I think you would need a lot more then diesel compression to compress gas enough to explode on its own.
Typical compression ratios for gasoline engines range from 8:1 to 10:1. (A gasoline engine with a 10:1 compression ratio is considered a high-compression engine.) Typical compression ratios for diesel engines range from 15:1 to 20:1.
Gasoline is more volatile (has, on average, lower molecular weight) than diesel fuel. So, gasoline ignites considerably more easily than diesel fuel does. This is why one must carefully control the spark timing in a gasoline engine, especially in a high-compression engine, to prevent excessive pinging/pinking/knocking.
/ Kubota Gas vs Kubota Diesel engine option #127
I think you are living in the past, modern high efficiency gas engines run as high as 16 to 1 on regular gas. My 4500P only turns 3100 to 3200 max. while the Kubota diesel turns 3600, .1 to.2 a gallon per hour difference plus more HP. and torque and the engine will work on steeper slopes. The cost of diesel here is over .50 a gallon more for diesel..... jim
/ Kubota Gas vs Kubota Diesel engine option #128
I do not see how one could achieve an actual 16:1 compression ratio in a gasoline engine without uncontrolled detonation (pinging/pinking/knocking). I think that the upper limit is ~ 11:1.
There are some gasoline engines, so-called Atkinson Cycle engines, e.g., the ones used in the Toyota Prius, that have a volumetric compression ratio in the range of 13:1 or 14:1. However, such engines employ delayed closings of the intake valves.
In such engines, for a portion of the compression stroke by a given cylinder, the intake valve associated with that cylinder remains open. Some of the air that had been drawn into the cylinder during the intake stroke is pushed back into the intake manifold. After the intake valve closes, the remaining air is compressed until the piston continues its upward travel and reaches top dead center. As a result of the delayed closing of the intake valve, the effective compression ratio is a good bit less than bottom-dead-center-to-top-dead-center travel distance, by itself, would indicate.
/ Kubota Gas vs Kubota Diesel engine option #129
I agree John. I had a 70 chevelle SS Ls-6 with 11.5 to 1 compression and I had to use Sunoco high test in it or it would ping like crazy.
/ Kubota Gas vs Kubota Diesel engine option #130
They do it and that is all figured in, my crv is a 1.5 and even has turbo and runs on regular. The best part is the high MPG. average is 31.5 for 16000 miles. Mazda has been running high compression for years on regular. yep old time high compression engines couldn't do it, that was then .... this is now..... jim
/ Kubota Gas vs Kubota Diesel engine option #131
My 2013 Impala is 11.5:1 compression ratio and uses 87 octane gas. It's GDI with variable valve timing, can make 300hp, and gets 31mpg on the highway at 75mph.
/ Kubota Gas vs Kubota Diesel engine option #132
MR, if you want to talk highway that is different story, 39-40 will happen and with all wheel drive to boot.... jim
/ Kubota Gas vs Kubota Diesel engine option #133
What I'm getting at is 11.5:1 compression used to be HUGE in the late 60's/early 70's. Today, it's normal.
/ Kubota Gas vs Kubota Diesel engine option #134
Compression ratio for a Mazda sky active 2.0 is 18 to 1, My CRV is 10.6 to 1 but turbo boost is 18-20 psi..... both on reg. gas...... jim
/ Kubota Gas vs Kubota Diesel engine option #135
The direct injection gas engines rely on the spark plugs for ignition at idle , light loads and low rpm. At high loads and high rpm the gasoline starts burning as soon as it is injected .
/ Kubota Gas vs Kubota Diesel engine option #136
Ever hear tell of the L86, LT1 and LT4 Chev V8 engine痴 ?
/ Kubota Gas vs Kubota Diesel engine option #137
Man times have changed since I last dove in a engine!
KUBOTA M5040D TRACTOR (A60430)
KUBOTA M5040D...
2019 Land Rover Range Rover Sport AWD SUV (A55853)
2019 Land Rover...
UNUSED KJ K1912 - 20' X 12' LIVESTOCK METAL SHED (A60432)
UNUSED KJ K1912 -...
(INOP) VOLVO A30D OFFROAD DUMP TRUCK (A60429)
(INOP) VOLVO A30D...
2022 BROCE BW260 SWEEPER (A60429)
2022 BROCE BW260...
2015 Doosan 750CFM T/A Towable Air Compressor (A59228)
2015 Doosan 750CFM...
