Picking up a L3301 and RCR2660
/ Picking up a L3301 and RCR2660 #1
tradosaurus
Super Member
Texarkana, TX
Kubota MX5400 HST, heavy duty bucket, 3rd function, R1 tires (rears filled), 2 remotes
Will be picking up a L3301 HST with R4 tires and RCR2660 rotary cutter next week. The cutter had to be ordered.
Will be adding a quick hitch, filled rear tires and 3rd function.
/ Picking up a L3301 and RCR2660 #2
Congrats! Send pictures when you can!
/ Picking up a L3301 and RCR2660 #3
Don't forget to change your profile! The L3301 is an excellent tractor for learning how to tractor on, and a great chore machine full stop. I've had mine almost 3 years now. I have my complaints, but it was as much tractor as I could afford at the time and it's done things I would have never thought of even trying without it, as well as making formerly back-breaking jobs simple.
/ Picking up a L3301 and RCR2660 #4
Get the rear tires loaded & always make sure you have proper ballast on the 3pt if you are using the loader. It's a good machine, but a little light in the back end.
/ Picking up a L3301 and RCR2660 #5
This. I almost always run out of traction before power, the standard Ls are all very light for their HP, barring maybe the L2501.
Also, the pucker factor is definitely there on slopes. I don't consider my hills anything amazing, but it can get not fun in a hurry if you're not careful.
Yes, I am having the rear tires loaded with water/antifreeze.
This is my first tractor of my 53 y.o. life. :)
/ Picking up a L3301 and RCR2660 #7
Congratulations.
You will be glad that you have it, and wonder how you got by without it. Just a word of caution though; tractors are a serious addiction. Before long you will "need" a backhoe or a chipper, then a tiller; and all those things really should be under cover so you will need a building to keep them in.
And we are all very helpful at spending other people's money...
I decided to go with R1 Ag tires after talking with an older fellow who has been running tractors for 30 yrs. He said R1 tires will shed mud better thereby getting better traction. Since I will be running in the woods mostly I decided this is the way to go. He also said that in 30 years he's had 2 flats.
I also decided to get a SGC0660 Claw grapple.
Tractor and attachments finally arrived today.
First thing I did was detached the grapple and forget to undo the two hydraulic hoses and dragged it a few feet before I remembered. Slight hydraulic leak at on the fittings now.
Other than that I ran the rotary cutter a bit. Tomorrow I will put the tractor to work hauling dead limbs and dead trees.
/ Picking up a L3301 and RCR2660 #10
I suggest you repair that asap. It's only going to get worse with time, and your tractor makes over 2000 PSI, so it could really let go if not addressed promptly.
/ Picking up a L3301 and RCR2660 #11
Congratulations, that is a nice little tractor and the cuter nice too, I have the RCR2672 with chain guards front and back. Afree on the weight and ballast too. I filled my tires added two sts of wheel weights and keep 1000 on my 3PH.
/ Picking up a L3301 and RCR2660 #12
Hey, don’t call his tractor cute...:)
/ Picking up a L3301 and RCR2660 #13
Agreed, my neighbors hydraulic hose let go on his L2501 when he got his grapple tangled up in some brush and it sprayed fluid out with force.
/ Picking up a L3301 and RCR2660 #14
I suggest not Googling hydraulic injection wounds unless you have a strong stomach. Usually followed by gangrene & amputation, if the extremity isnt amputated by the event itself. Which can happen at a surprising distance from the leak itself. Hydraulic leaks are closer to a water jet cutting stuff than a garden hose.
/ Picking up a L3301 and RCR2660 #15
UNUSED FUTURE EQUIPMENT SEAT (A60432)
UNUSED FUTURE...
2001 PETERBILT 379 (A58214)
2001 PETERBILT 379...
ATHENS PLOW CO. 55-7' DISC HARROW (A60430)
ATHENS PLOW CO...
2024 Load Trailer 20ft T/A Flatbed Equipment Trailer (A56859)
2024 Load Trailer...
iDrive TDS-2010H...
2024 COLEMAN MINI BIKE (A58375)
2024 COLEMAN MINI...
