leonz
Super Member
Hello Rick,
Measure the from the center line of the stub shaft of the gearbox on the snow caster and then compare it to the centerline height of the mules PTO stub and please note it on your next response as the propeller shaft HAS TO HAVE a very shallow angle of approach(slope)(rise and run) to the mules PTO stub.
if you have some nylon twine you can visualize this more readily by wrapping the nylon twine around the PTO stub of the mule and then doing the same thing to the stub shaft of the snow caster to obtain the angle.
You either use the top of the PTO Stub and the top of the stub shaft on the gearbox or the bottom of both stub shafts as long as you have wrapped the twine around it 3 or 4 times.
This will only be off by 3/4 of an inch or so due to the diameter of the stub shaft but you will see the angle of the slope and then you will see how it is too high in slope to allow the universal joints to work with minimal stress.
