I want to replace my 1969 David Brown 780 that I've been using for nearly 20 years mostly for snow removal using a five foot rear snowblower. The DB 780 also has a FEL. I have only just begun researching replacement options so I welcome suggestions.
My wish list for a new tractor includes: diesel, 4WD, heated cab, front mount snowblower, FEL, and smaller than the DB 780 so it's easier to get in my shed. I currently use the FEL in the winter mostly to move the thick crud left by state plows where my long drive meets the highway. I think I can get away without the FEL in the winter by adding a blade on the three point hitch but it would be nice to easily switch between snowblower and FEL if necessary.
I believe the B2650 is the smallest Kubota with factory cab option. I talked to a Kubota dealer about my wish list and he came up with a $32K price tag for the B2650 including cab, 51" snowblower, FEL with 60" bucket and quick hitch to easily switch between snowblower and FEL. I haven't talked to them yet but found my nearset Kiota dealer has a listing for a CS2510 with snowblower, cab, and FEL for $21K.
Why the $11K difference between the CS2510 and B2650? I imagine the Kioti doesn't have quick hitch and I'm not sure its snowblower has chute deflector control from the cab. I've reviewed the specs on each at Tractordata.com and the B2650 appears bigger and heavier with greater lift capacity, and has A/C in the cab (which I don't need). Both dealers are two hours away. Any thoughts are welcome.
