2010C, need to get it started!
   / 2010C, need to get it started! #11
According to machine serial number you posted you should have the later style injector(key 19). T18533 Turbulence chamber(key 5) with stripped threads is NLA from JD
   / 2010C, need to get it started! #12
WOW.. IF THATS what u have {post # 11} I pity u.. $300.00 for an injector.!!?? THATS just robbery.!!
I sure hope its just the screw that's stripped.!!
I've been working in fuel injection for 30+ years AND worked at AMBAC{injector manuf}.. & have never seen that injector.!!
Normally I could call the factory{Ambac} & get a core or part & get u going.. But I've been all over their "core" area & haven't seen 1 like THAT..
NOR in the fuel shop I worked at..
The screw shouldn't be that hard to find or MAKE.. find a bolt w/ the correct threads & hold the threads on a grinder to make a flat & your done..
ALL the new return bolt threads are like THAT.. They figured out that drilling a hole THRU & then a hole "sideways" was compromising the strength & now they just make a "flat" so the fuel can leak past & into the return rail..
Now the pump is a diff. story.. I can do that in my sleep..
Yes this is correct, but the picture you posted before is not the correct injector, that one was the series after.
Normally
I can have the pump done locally, but it is in fact the inside of the injector that is stripped out from someone over tightening the banjo bolt I’m sure.
   / 2010C, need to get it started! #15
It's dawned on me what you're stating about the inside of injector is stripped out where bolt that attaches/seals fuel line to injector.
Yessir that is correct.
   / 2010C, need to get it started! #17
So ITS NOT the inj, in post #7??
IF NOT then I'm gonna need a pic of it.. some GOOD pictures.. & I'll probably have an idea that might work.
If its easier, u can send them to my home email.. just use my screen name & add @ a o l dot com in your HOME mail server..
   / 2010C, need to get it started! #18
post 7??? Do you mean post 9??? I incorrectly posted that photo because I didn't check machine serial number. Have you looked at my post #11?
The one in post 11 is correct.
Part number AT16344
LARGE METAL RACK W/ 5 LEVELS (A58374)
LARGE METAL RACK...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
PALLET OF SQUARE TUBING & ROUND STOCK (A52708)
PALLET OF SQUARE...
2019 Chevrolet Tahoe SUV (A56859)
2019 Chevrolet...
2016 Club Car Carryall 710 Electric Utility Cart (A55853)
2016 Club Car...
New/Unused Double Stall Portable Toilet (A57453)
New/Unused Double...
