ovrszd
Epic Contributor
- Joined
- May 27, 2006
- Messages
- 32,246
- Location
- Missouri
- Tractor
- Kubota M9540, Ford 3910FWD, Ford 555A, JD2210
Re: Big Barn痴 Retirement Farm Shop
That's what I was inquiring about Terry.
My table weighs somewhere around 500lbs. I wanted it to be easy to move so I put very good quality 6" casters under it. Swivel casters on one end. I move it a lot so this has been great. Very easy to push it around even with an additional 300lbs of steel piled on the bottom shelf. Problem is I can't do much heavy work on the table without screwing the locks down. It rolls away from me. Especially if doing vise work.
I had originally thought I'd design and build pads that would be pedal operated. Ideally one pedal would raise the table up on the wheels. Release and it would settle on adjustable pads for leveling. After I struggled to design and build a folding cutting table on one end I gave up on the more complicated stabilizers. I think you actually helped me figure out the design on the folding cutting table. Thanks for that.
