455 won't start...but it cranks
   / 455 won't start...but it cranks #11
My 455 did something similar, long story short it ended up being a loose ground on the fuel shutoff solenoid. Remove the left side panel and you will see it. My problem started as a coughing/sputtering problem, turned into a "won't start" problem before I found it.
   / 455 won't start...but it cranks #12
The fuel solenoid pull-in coil is high current. Could be up to 5 amps. If you have a poor connection someplace along the current path, then the pull-in may not operate and thus, no start.
I agree with other posters. Corroded connectors, poor crimp or just a poor ground can become a problem.
Keep looking.
Richard
   / 455 won't start...but it cranks #13
I have the problem in the morning .you crank it and crank it maybe half hour then it starts. then it works good all day. I usally trouble shoot it myself this time had jd mechanic look at . he thinks its a sensor hopefully it is
   / 455 won't start...but it cranks #14
I believe OP found a bad fuel shut-off but you said something that might interest owners. A mechanic should have knowledge of testing proceedures and know what's wrong. Dealer that throw parts at it until fixed is a hack,not a mechanic. Owners can buy and install parts themselves much cheaper than paying $80-$100 per hour plus mark-up on parts. As you said "hopefully"he's right the first time.
   / 455 won't start...but it cranks #15
was on a job didn't have time to look at it . ill post what outcome from it .lol and its 120 per hour and will not be allowing guess work for sure.
   / 455 won't start...but it cranks #16
   / 455 won't start...but it cranks #17
1400 hr 2011 jd tractor
   / 455 won't start...but it cranks #18
diesal
This must be your listed 4720 and not the 455 model in the subject of the thread.. ??
   / 455 won't start...but it cranks #19
that's right 4720 2011 jd
   / 455 won't start...but it cranks #20
once I get it going it stays working . ive been using it 12 hrs a day snow removal . 10 days now .it works the very best when it starts . reading up on the manual now
2014 Ford Explorer AWD SUV (A55853)
2014 Ford Explorer...
2015 Kubota RTV-X900 4x4 Utility Cart (A55787)
2015 Kubota...
2016 Dodge Charger SRT Hellcat Sedan (A55758)
2016 Dodge Charger...
2006 International 7400 Tandem Axle Dump (A47477)
2006 International...
Giyi 44" Rock Bucket (A53316)
Giyi 44" Rock...
